1/2 ton axle swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2013, 10:53 PM   #1
The Tank
Default 1/2 ton axle swap
I just got a dana 44 front and a 14 bolt rear and I was woundering what I need to swap them out with my 1/2 ton axles under my 88 burb. like I have a 8in suspension lift on it now and was woundering if I needed new u bolts cuz of the bigger axles or diff leafs.
The Tank is offline   Reply With Quote
Old June 20th, 2013, 07:09 AM   #2
RADRICK
RADRICK's Avatar
For the rear yes, for the front measure the tube & u bolts. But mostlikley the fronts will need to be replaced too.
Old June 20th, 2013, 07:20 AM   #3
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
From past experiences, You should always replace U-bolts. I have reused them and they never seem to stay tight when they have been used before.
lepp1892 is offline   Reply With Quote
Old June 20th, 2013, 07:28 AM   #4
bigdgmc
Anger Management
bigdgmc's Avatar
fronts will be the same as whats under there now. if the rear is a ff it will definitely be bigger.
bigdgmc is offline   Reply With Quote
Old June 20th, 2013, 08:28 AM   #5
Theblueghost
I can add some light to this since I know him personally and helped him put on his lift. His you bolts are brand new every thing under the truck was replaced. But I'm doing a sas swap on my 98 chevy and we got a killer deal on axles and he's wondering if it's worth it pretty much. Also what he would have to change.
Sent from my SPH-M900 using Tapatalk 2
Theblueghost is offline   Reply With Quote
Old June 20th, 2013, 08:37 AM   #6
bigdgmc
Anger Management
bigdgmc's Avatar
needs to have new spring plates for the rear axle since the new axle is bigger. new u bolts for the rear for same reason. and will have to change the u joint on axle end of rear drive shaft to accept bigger yoke on the 14 bolt.
Old June 20th, 2013, 06:48 PM   #7
The Tank
okay by what mean do u mean about bigger spring plates the spring purches on the axles have to get redone. and am I going to need bigger leaf springs cuz the ones I have are ones for the stock 1/2 ton axles
Old June 21st, 2013, 07:08 AM   #8
bigdgmc
Anger Management
bigdgmc's Avatar
no you dont need bigger or different springs. you dont need to re-do your perches. the spring plates are the plate that the u-bolts go thru that sit atop of the spring to hold the spring to the axle. bigger diameter axle = bigger bolt hole span of spring plate and u-bolt size
Old June 26th, 2013, 06:43 PM   #9
The Tank
okay thx. do u know where I can get that special u joint that goes from 1/2 ton drive shaft to the 14 bolt yoke. let me know.
Old June 26th, 2013, 09:07 PM   #10
Wramblerguy
Wramblerguy's Avatar
Any parts store
I believe they are referred to as "change" u-joints
3rd generation jeeper
Old June 27th, 2013, 01:11 PM   #11
littletrucker
I'd hit that
littletrucker's Avatar
1310 to 1350 = Spicer 5-460X Or Precision #348
1310 to 1330 = Spicer 5-134X
1330 to 1350 = Spicer 5-648X
Page generated in 0.24318 seconds with 56 queries
