jeep help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2013, 09:55 PM   #1
immarockstar21
xj jk
immarockstar21's Avatar
Default jeep help
hello everyone i was wondering if there would be a down fall if i added 3 in coil spacers and 1.5/2in rear shackle kit to my xj that is already has a 3 in suspension lift? i know i would need to buy new shocks but is there anything else?
immarockstar21 is offline   Reply With Quote
Old June 19th, 2013, 11:33 PM   #2
sandfox4
napadave
sandfox4's Avatar
figure on a full set of front adjustable control arms, or long arm the front, 6 inches on short arms will not be good
sandfox4 is offline   Reply With Quote
Old June 19th, 2013, 11:39 PM   #3
XJsport95
Haters be my motivators!!
XJsport95's Avatar
Brake lines, SYE kit, drive shafts, pitman arm and all the stuff sandfox said. That's just the tip of the iceberg,
XJsport95 is offline   Reply With Quote
Old June 20th, 2013, 12:07 AM   #4
immarockstar21
xj jk
i have the extended control arms. why would i need the brake lines and drive shafts
Old June 20th, 2013, 12:14 AM   #5
immarockstar21
xj jk
what else would i need down the road? because all i thought i needed were the shocks to go with the coil spacers
Old June 20th, 2013, 06:52 AM   #6
jbsjunk
Little Member
jbsjunk's Avatar
If it was stock, this may be the case. Also, with a dropped pitman arm you will need a new track bar and frame bracket or you will get bumpsteer like a mofo. I like the BDS version. The more you go up, the more you will need to change. Like the SYE kit and rear driveshaft.
Old June 20th, 2013, 11:38 AM   #7
immarockstar21
xj jk
Ok so it goes from a $200 project to a $1000 project?
Old June 20th, 2013, 01:46 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
If you're lucky you'll get off that cheap. Good stuff isn't cheap. Cheap stuff you buy a dozen of and finally get the good stuff.
Old June 20th, 2013, 04:32 PM   #9
immarockstar21
xj jk
thats true i guess i will pass on the coil spacers
Old June 26th, 2013, 11:40 PM   #10
immarockstar21
xj jk
if I just get a 6in lift kit would I need all that stuff still?
Old June 27th, 2013, 07:52 AM   #11
jbsjunk
Little Member
jbsjunk's Avatar
Yes.
Old June 27th, 2013, 08:13 AM   #12
89cjwftw
jeeprbrown
89cjwftw's Avatar
either way you go yes you will need all the stuff mentioned above.
89cjwftw is offline   Reply With Quote
Old July 17th, 2013, 06:39 PM   #13
immarockstar21
xj jk
ok thank you
Old July 17th, 2013, 07:41 PM   #14
skife
skife's Avatar
unless the 6" lift kit includes all the stuff.
Old July 17th, 2013, 11:49 PM   #15
immarockstar21
xj jk
yeah but it would be a expensive one
Old July 18th, 2013, 11:26 PM   #16
yyj87
yyj87's Avatar
Leave the suspension and buy a lunch box locker or two.
Lockers get you places!
yyj87 is offline   Reply With Quote
Old August 2nd, 2013, 05:23 PM   #17
immarockstar21
xj jk
what do you suggest
Old August 4th, 2013, 09:39 AM   #18
yyj87
yyj87's Avatar
what do you suggest
They are all about the same. I have 2 Aussies and they work great.
Old August 4th, 2013, 12:39 PM   #19
Wehan
Wehan's Avatar
X2 on Aussie, no tire size or horsepower limits for warranty unlike the spartan locker that has a tire size limit of 32".....just like the pos Detroit ez-locker (epic fail)
"Our roots must balance our branches"
Wehan is offline   Reply With Quote
Page generated in 0.50263 seconds with 80 queries
