1995 f250 4x4 ****GONE*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2013, 03:08 PM   #1
frdboy
frdboy's Avatar
Default 1995 f250 4x4 ****GONE***
I am keeping the engine, front axle, and the tires/wheels have a deal pending.
Truck has 75K miles on it.
Just about everything else available.
Box is trash and the cab is smashed in under the rear window.
Manual doors in good condition, just some surface rust on the lower inside but very soild yet. 75.00 ea.
Front fenders in good condition 40 ea. SOLD
E4OD trans, sbf bolt patttern, fluid looks great, $250.
Rear axle, 4.10 gears from what I can read on the tag, $100.00
1356 T-case $125.
bench seat $50.
frdboy is online now
Old June 19th, 2013, 07:32 PM   #2
97jeepcherokee
i got the jeep thing
97jeepcherokee's Avatar
what color is the bench seat? im interested in that. also how much for the transfer case shifter bracket that bolts to the trans if its a manual t-case. and if its a dual tank i need the front tank assembly and the switcher valve for the tanks if its a dual tank. if you have the factory hubcaps i need a couple of them also.
call or txt or pm (616)889-7477
thanks. mark
97jeepcherokee is offline
Old June 19th, 2013, 07:37 PM   #3
frdboy
frdboy's Avatar
thanks. mark
The int. is light blue
it is a man. shift case but the tcase shifter is really stiff.
I will check out the tank and valve and see what condition they are in.
Old June 19th, 2013, 07:48 PM   #4
97jeepcherokee
ok dont force the shifter thats how mine broke before i bought it. as long as the aluminum isnt broke im interested. i can free up the linkage. as for the seat its the worst color so ill have to pass on that. and let me know about the tank deal and be sure the pump works on that tank.
Old June 19th, 2013, 07:52 PM   #5
97jeepcherokee
also need a tailgate if its decent. color doesnt matter.
Old June 19th, 2013, 08:10 PM   #6
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
I will take the front fenders, talk to you on Friday.
FORD FLARESIDE is offline
Old June 19th, 2013, 08:13 PM   #7
frdboy
frdboy's Avatar
Old June 20th, 2013, 12:50 AM   #8
NewGuy
Core support?? May need some other thing once I look over my new project
NewGuy is offline
Old June 20th, 2013, 09:12 PM   #9
Goat
Goat's Avatar
Send a message via Yahoo to Goat
Hows the plastic panel that bolts to the core support and the headlights bolt to? Also interested in the trim piece that goes under the grill and headlights. pm me price and condition of both please.
Goat is offline
Old June 21st, 2013, 01:11 PM   #10
frdboy
frdboy's Avatar
I will check it out and get back with ya, probably will be Monday though.
Old June 21st, 2013, 05:15 PM   #11
97jeepcherokee
any updates on the t-case shifter and the front gas tank
Old June 21st, 2013, 07:09 PM   #12
vteckickin
how is the bed like how bad
vteckickin is offline
Old June 22nd, 2013, 03:00 AM   #13
NewGuy
VERY interested in the core support! I need it bad!!!
NewGuy is offline
Old June 23rd, 2013, 10:02 PM   #14
kmanxj5011
kmanxj5011's Avatar
How much for driver side mirror? I'm assuming its manual? Do you know if the leaf springs are the same as what would be in a truck with a psd? If they're the same how much?
Thanks
kmanxj5011 is offline
Old June 24th, 2013, 08:24 AM   #15
frdboy
frdboy's Avatar
Looks to be in good condition, $75
Old June 24th, 2013, 08:38 AM   #16
frdboy
frdboy's Avatar
It starts and runs on the front tank and doesn't appear to be terribly rusty, there is not a bunch of fuel in it so no idea on if it leaks or not.
$75 for the tank and valve but I would like to wait to pull it till I am ready to pull the motor so the truck is still movable. Probably be a couple of weeks.
Old June 24th, 2013, 08:39 AM   #17
frdboy
frdboy's Avatar
Thanks
I would think the springs are different, I would like to see if someone wants the doors first before I start taking them apart.
Old June 24th, 2013, 08:43 AM   #18
frdboy
frdboy's Avatar
I can get some pics later.
Old June 24th, 2013, 09:23 PM   #19
NewGuy
I will take the core support as long as its in good shape!!!
NewGuy is offline
Old June 24th, 2013, 09:29 PM   #20
frdboy
frdboy's Avatar
Sounds good, I will see when I can get some time to get it out.
Page generated in 0.39613 seconds with 83 queries
