What accessories on an AR? - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Other Stuff > The Great Outdoors
The Great Outdoors Guns, Cannons, Fishing, Camping, and other fun stuff
Old June 18th, 2013, 12:38 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default What accessories on an AR?
What do you guys prefer? Looking at them, trying to think of what to look for as far as accessories on one.
Old June 18th, 2013, 12:40 PM   #2
Bullhed78
Bullhed78's Avatar
Depends on the purpose of the rifle. What do you plan on using it for?
Bullhed78 is offline   Reply With Quote
Old June 18th, 2013, 03:56 PM   #3
FlatFender
Tap Tap Splat
FlatFender's Avatar
Long free float rail
1-4x optic (Burris MTAC)
VTAC sling
Mags
Ammo
Old June 18th, 2013, 04:49 PM   #4
jeepfreak81
81 inches of fun
Mostly collecting dust in the cabinet pissing off Uncle Sam that I have it. Other than that, target practice and awaiting the Zombie Apocalypse, what else?
VTAC sling
Mags
Ammo
Any brands of mags to stay away from?
Old June 18th, 2013, 06:05 PM   #5
SS
Bananarama!
SS's Avatar
Quad rail of your choice. It doesn't have to be a free float.
Weapon Light
Iron Sights
Sling
PMags (Ten)
Lots and lots and lots of ammo.
-Jer
SS is online now   Reply With Quote
Old June 18th, 2013, 06:35 PM   #6
Waychoff05
Waychoff05's Avatar
nice quad rail and a nice pistol grip.
Waychoff05 is offline   Reply With Quote
Old June 18th, 2013, 07:27 PM   #7
Easy_E
Web Wheeler !
Easy_E's Avatar
Here's my list
Ambi controls (at least the safety)
Red dot with backup iron sights
Convertible sling single to two point
Free float rail
Ammo lots of ammo !!
Easy_E is offline   Reply With Quote
Old June 18th, 2013, 08:36 PM   #8
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Iron sights, pmags, ammo, single point sling
Old June 18th, 2013, 08:41 PM   #9
kp99xj
kp99xj's Avatar
I would not add on a ton of accessories if they are not needed for your application. It depends on what you are using it for. If just for shooting targets in the backyard, get some optics or iron sights you like and some ammo.
All the extras just add weight and get in the way if they are not needed.
kp99xj is offline   Reply With Quote
Old June 19th, 2013, 01:15 AM   #10
busyfixin
Balls Deep
busyfixin's Avatar
Free float tube, NOT a quad rail
Trigger mods or drop in
National Match front sight pin
Convertible sling
Flat top w/carry handle & NM sight
Reflex sight or ACOG type sight
Old June 19th, 2013, 01:26 AM   #11
busyfixin
Balls Deep
busyfixin's Avatar
Agreed. Bolting on a bunch of BS is retarded unless you need them. Pic rails and quick releases are designed to put on what you need, when you need it. Not all at once. (unless you need it) For example, a sunshade and flashlight are not needed at the same time. A bipod and flashlight are not usually needed at the same time either. If your light is good enough you can see far enough to use a bipod, it's worth enough to take it off in the daytime and keep in your pack. A bayonet and 30 power scope shouldn't be attached at the same time.
Old June 19th, 2013, 01:27 AM   #12
oz97tj
Wasn't this attached?
oz97tj's Avatar
Like everyone else said, don't overdo it. They get heavy and retarded quickly.
I have the quad rail with a lightweight foregrip and a light with pressure switch mounted up front. A Urban-ERT sling which can be converted to single point or two point quickly and easily. Its by far the best sling I've had and I've had a bunch. The owner is also pretty cool and has similar ideals to most of us. Lastly, I have a Redi-Mag mounted to the side of the receiver. I wouldn't consider this a needed item for most and frankly it is kind of heavy, but for the purpose I got it for it works great.
********GLFWDA.org********
Old June 19th, 2013, 07:52 AM   #13
Bullhed78
Bullhed78's Avatar
I agree with the people saying not to load it down with a bunch of shit. Keep it simple. Iron sights and some sort of optic. As you use the rifle you will start to know what you want on it. It is definitely a learning experience. To start with I say buy a nice plain Jane rifle and lots of ammo. I have had good luck with standard steel mags and Pmags.
Old June 19th, 2013, 09:55 AM   #14
SS
Bananarama!
SS's Avatar
You don't need a free float tube. For what you're doing there will be no added benefit versus a drop in quad rail.
-Jer
Old June 19th, 2013, 10:28 AM   #15
bgh1441
bgh1441's Avatar
Mine has a quad rail, eotech, flip up iron sights, magpul furniture, and a single point sling.
Honestly just use the K.I.S.S method best thing to live by with ar's. Adding everything on them makes them a lot heavier. Avoid the flashlights and lasers, to me they are added weight that serve no purpose on a safe queen/ range gun. Foregrips are ok but not needed and can get in the way if you use a bench at the range.
bgh1441 is offline   Reply With Quote
Old June 19th, 2013, 11:04 AM   #16
kp99xj
kp99xj's Avatar
As for FF rails, lately I am in love with the Fortis Rev. Super lightweight, not overly bulky, and comfortable on the hand. Also love the Troy Alpha, but I also like to be different and not have the same setup as every other guy out there.
Here is a pic of the Fortis rail that has been cerekoted in tactical grey color.
Old June 19th, 2013, 03:19 PM   #17
jeepfreak81
81 inches of fun
Wow that looks nice... I will have to save some money for that.
Old June 19th, 2013, 03:45 PM   #18
DuffMan
Your Message Here
DuffMan's Avatar
A good sight. Otherwise, it's a carbine - which means light. Stop junking them up!
Old June 19th, 2013, 07:20 PM   #19
I suck cocks. Lots of them.
locally famous
i would suggest a cigarette lighter.
Old June 19th, 2013, 10:26 PM   #20
Easy_E
Web Wheeler !
Easy_E's Avatar
I just put this upper together and shot a hundred rounds tonight thru it. Man does it work great. PSA 10.5 " barrel 11" handguard.
Here is a friend holding it....
Page generated in 0.40701 seconds with 83 queries
