1999 f350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2013, 02:31 PM   #1
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Default 1999 f350
Looking at a 1999 F350 CCLB. It has 254K on it, auto trans, manual transfer case, Warn Lock outs. It's set up to plow, and the frame looks straight. Asking price is 5K. Anything else I should be looking for/ at that would be a deal breaker?
I should add, this is for my parents. It's sole job will be to haul their 26 foot cruiser, and occasional Menards trips ect. Estimated annual mileage, is 4000-5000 miles.
Old June 16th, 2013, 08:06 PM   #2
kickstand
circling the drain
kickstand's Avatar
what motor?
Mine was a 7.3 needed and a windsheild seal, which fried the GEM, which killed both batteries daily, wouldn't shift out of 4 low (electric transfer case) The door lock actuators stopped working, the door sensors needed constant lubing to allow the truck to realize the doors were shut, the oil pan was rusting through, it leaked fuel, the rear diff speed sensor was replaced twice, the gas pedal went out twice ($450 each). I replaced the driver rear caliper 2 or 3 times. Figure a complete front end rebuild runs about $450 for parts but thats everything (Tire rods and ball joints).
Other than that it was a great truck.
Old June 16th, 2013, 08:24 PM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
what motor?
I replaced the door lock actuators, tires, fuel drain valve, batteries and brakes all the way around...it has needed nothing else, it's been a great truck
Old June 16th, 2013, 08:38 PM   #4
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
If its a 7.3 has the trans been gone threw and upgraded?
Old June 16th, 2013, 09:16 PM   #5
GREASYHANDS
GREASYHANDS's Avatar
Looks like a gasser
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 17th, 2013, 07:25 AM   #6
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
what motor?
7.3
One of The issues you had with yours is one of the reasons I like this truck. It has the manual engagement (on the floor) for the Transfer Case.
No idea. It's at a dealer. I took it out and romped in it and it shifted quite smooth. I'm going to look at it again this morning. Pending a major rusted oil pan, I think it's a go.
Old June 17th, 2013, 07:29 AM   #7
kickstand
circling the drain
kickstand's Avatar
I'll add, if that's a gasser the price seems "ok" not awesome. If they are only going to put 4-5,000 miles on it per year I'd suggest storing it inside. Any amount of moisture will reek havoc on the electrical systems, especially if the windsheild seal is bad at all (mine was real bad and in the end literally killed the truck) and there's any moisture in the truck while its sitting.
My truck had 220k or so on it when I sold it. Mine was starting to get crusty from being parked outside and not driven often. With that being a plow truck, i'd be weary of what the salt in parking lots (or his spreader) has done to the underside of the truck.
*edit* Mine was on it's second transmission. I never had a transmission problem.
Even with all of the electrical issues and crap going on with my truck I was lucky that it never left me stranded. Over the 2+ years I owned it, it was always solid on road trips. As the GEM issues got worse it did become a major chore to get it started however.
Old June 17th, 2013, 07:32 AM   #8
kickstand
circling the drain
kickstand's Avatar
Originally Posted by MonkeyBiz View Post
7.3
The staying in 4 lo was related to the GEM, not any of the parts in the 4x4 system. The point is make sure you check out all of the electrical and make sure there are not any quirks, also before you buy it do some google searches on finding a GEM should yours go bad.
Old June 17th, 2013, 03:57 PM   #9
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Well, I came out side this afternoon, and here it is. I said, "you go home you naughty truck!" but it won't leave. Even followed me to work.
Old June 19th, 2013, 11:33 AM   #10
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
I'm the man in White.
Old October 25th, 2013, 05:54 PM   #11
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Finally got it out of the body shop today. It recieved:
2013 take off box
2013 take off bumper
New Cab corners (both sides)
New Rockers (both sides)
New door inner panels (all 4)
New ID lights
New Chrome body kit
Roof rust @ ID lights repaired
Entire cab paint job
Brush guard blasted and re poweder coated
Rear frame cross member replaced and under body coated
Old November 4th, 2013, 11:02 PM   #12
vteckickin
this is my buddys old truck we use it as a landscaping/plow truck for 4 years
vteckickin is offline   Reply With Quote
Old November 4th, 2013, 11:35 PM   #13
14muddn
2013 take off box
New ID lights
New Chrome body kit
If you don't mind me asking what did you pay to get the rust repair and cab to be painted?
Old November 4th, 2013, 11:45 PM   #14
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
The whole thing was <5K. All the paper work is in the truck right now, so I don't know what just the rust repair/paint job cost. Got the bed LineX ed Friday, and dropped it off this morning to get Ziebart 2 stage under-body coating applied. Hopefully this truck runs for a long time.
Old November 5th, 2013, 12:30 AM   #15
14muddn
That's not too bad It seems like the new beds have been going for 2k alone. I need to do the same thing to my truck before too long. looks good by the way
Old November 5th, 2013, 08:25 AM   #16
Bones
Bones's Avatar
throw some 2002 headlights on it and it will look amazingly new
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 5th, 2013, 04:02 PM   #17
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Got the bed from a guy in Lowell. He picked it up in Oklahoma as a factory take off. 1300.00.
Page generated in 0.57347 seconds with 74 queries
