Tracker Crawler Krawler Reds Fox Shocks Full Hydro Caged Propane . - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2013, 12:01 PM   #1
Rubilooe
Rubilooe's Avatar
Default Tracker Crawler Krawler Reds Fox Shocks Full Hydro Caged Propane .
Rig was completed in May 2011. Buggy is titled , although its main function is offroading so luxuries for on road driving are greatly reduced. it is 100% turn key and ready to wheel and is built to handle a beatdown. specs are as follows...
Chassis...
custom 1.5" .120" wall tube added to about 4 feet of a remaining Tracker frame
99" wheelbase, 19" belly. 6'2" overall height
Drivetrain...
1/4" DOM Drive Shafts recent replaced u joints
stock suzuki 8 valve engine into a 2wd tracker trans into a 6.5 samurai t-case
Runs on Propane using a Gotpropane.com kit two runs since propane installed at which time a complete tune up including everything and a oil change.
Axles...
toyota 8" welded w/ 4.10 gears. front axle it fitted with 6 shooter knuckles, dirty 30 shafts, and trail gear full hydro steering.
rear is trussed and has gm disk brakes
Suspension...
3 link front w/ panhard and 16" fox 2.0 airs
3 link rear w/ top wishbone and 14" fox 2.0 airs
all joints are 2.5" johnny joints
Onboard Air and Hand Throttle .
Wheels/Tires...
37" red label Krawlers on 8" soft 8 whees w/beadlocks 17"
This works perfect and is turn key , maintained flawless needs nothing turn the key and it will take through the toughest trails .
lots of detail and quality work so many items that require a rig of this caliber to work most likely are not listed .
8200.00 Cash
Trades Jeep Wrangler TJ or YJ . Cannot have any rust period , built or stock .
Paper work from the build come with it well over 20K invested and lots of time .
269-858-5620
KDN KUSTOMS
Rubilooe is offline   Reply With Quote
Old June 24th, 2013, 10:15 AM   #2
Rubilooe
Rubilooe's Avatar
Default Trades welocome .....price reduced
8200.00
or trade for a Cherokee or Wrangler
269-858-5620
KDN KUSTOMS
Old June 24th, 2013, 02:59 PM   #3
mattt8430
Free bump, thanks for pulling out my poop cj at bundy
mattt8430 is offline   Reply With Quote
Old June 25th, 2013, 09:19 AM   #4
Rubilooe
Rubilooe's Avatar
Default poop
you are welcome and thanks for the bump.
KDN KUSTOMS
Old June 28th, 2013, 11:33 AM   #5
Rubilooe
Rubilooe's Avatar
Default btt
Sold
KDN KUSTOMS
Page generated in 0.16337 seconds with 38 queries
