98 cummins with no headlights - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 15th, 2013, 04:36 PM   #1
zthatzmanz28
Life on a lazy river
zthatzmanz28's Avatar
Default 98 cummins with no headlights
I have parking lights and bright ligts when lever is pulled.
Changed:
Headlight switch
Dimmer / signal switch
40 amp fuse in PDC
Ideas where to look next?
zthatzmanz28 is offline   Reply With Quote
Old June 15th, 2013, 05:03 PM   #2
firehawk
Live Action!
firehawk's Avatar
Check the grounds and see if you have power and grounds to the headlights at the plug.
Check the relay also.
Old June 15th, 2013, 05:40 PM   #3
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
May sound stupid but did you think to try changing bulbs they are dual filament and both low beams could be burnt out.
Old June 23rd, 2013, 11:39 PM   #4
rammanriley
rammanriley's Avatar
Was the connection on the switch burnt?
Sent from my DROID RAZR using Tapatalk 2
96 Ram 1500 ECSB 5.9l v8 4x4 On 35's
13 Dart Aero (turbo go fast)
rammanriley is offline   Reply With Quote
Old July 31st, 2013, 06:06 AM   #5
tj84
tj84's Avatar
I have a 96 and had my head light switch go bad kinda common . you can get them at auto zone for around 20 bucks.
tj84 is offline   Reply With Quote
Page generated in 0.19630 seconds with 38 queries
