O2 removal - proper torch useage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 14th, 2013, 10:18 AM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default O2 removal - proper torch useage
2002 TJ 4.0L
Removing Upper Front Pre Cat O2
I have been trying to remove the O2 for quite some time now with no luck. Started with a o2 socket and that just bent, then used a wrench but wouldn't budge, then let it heat up from driving and still nothing. I went out and purchased one of those hand torches but it still wouldn't come off.
I let the torch sit on the o2 for about 35 seconds but still nothing. The part where the o2 plugs into the exhaust did not get cherry red, this is ky first time ever using a torch so I'm not sure if I did it right or not.
Should I let the flame sit on the part where it screws in longer? Or does turning the turn valve on the torch make it hotter or is that just for distance?
Thanks
Catnip 0_o is offline   Reply With Quote
Old June 14th, 2013, 10:39 AM   #2
branch92
Only in a jeep
branch92's Avatar
Heat the bung up till it is red if that doesn't work heat it up again and quench it by pouring water on it and then try and turn it out
branch92 is offline   Reply With Quote
Old June 14th, 2013, 10:40 AM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
Get a good penetrating lubricant (PB Blaster or seafoam deep creap are my choices) spray it on there and let it sit, i would spray a few times every 10 minutes.
Get a closed end wrench that fits it (If you can, most i've been able to) and get that over the sensor, if the plug in the way cut it, if you are replacing no loss, if not splice the wires together later.
With the wrench on, tap the end of the wrench with a hammer. The impact should help to loosen the rust bond in the threads in addition to the lubricant.
Old June 14th, 2013, 11:54 AM   #4
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Is PB blaster flammable?
Old June 14th, 2013, 12:50 PM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
totally lol
That said, i've removed a ton of O2 sensors and never had to resort to a torch.
Page generated in 0.19095 seconds with 38 queries
