Where to buy sheets of plastic? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 13th, 2013, 09:15 PM   #1
firehawk
Live Action!
firehawk's Avatar
Default Where to buy sheets of plastic?
I first wrote "Where to buy plastic sheets?"
But I thought people might think I pee the bed so I changed it.
So I am looking for 1/8" black textured plastic, would look like automotive interior texture. Will be building gauge pods out of it and will need to glue pieces together so I need to source the proper glue for it too.
Not sure how much I need but maybe a 4'x4' piece or 2' x 2' to start.
Old June 13th, 2013, 09:17 PM   #2
Bones
Bones's Avatar
fabrics store
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 13th, 2013, 09:24 PM   #3
firehawk
Live Action!
firehawk's Avatar
Originally Posted by Bones View Post
fabrics store
Really
Ok, I will check that
Old June 13th, 2013, 09:31 PM   #4
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
Alro
Old June 13th, 2013, 09:32 PM   #5
Bleay
sick of jackstand wheelin
Bleay's Avatar
Alro Plastics - Detroit
34401 Schoolcraft Rd.
Livonia , MI 48150
Phone: Use (800) 877-2576
Fax: (517) 787-6380
Contact this location
Driving directions
Bleay is offline   Reply With Quote
Old June 13th, 2013, 09:40 PM   #6
firehawk
Live Action!
firehawk's Avatar
Thanks
But
I
Just
Bought
Some
From
Ebay
$5 per 12"x12" piece shipped.
Old June 13th, 2013, 09:40 PM   #7
BlooMule
Old School
BlooMule's Avatar
Laird Plastics by 696/Groesbeck
-rw-rw-rw
Old June 13th, 2013, 09:41 PM   #8
Jiveturkey3
Jiveturkey3's Avatar
Www.knifekits.com
I buy all my Kydex from them. It would work great for what you are wanting to do. Read up on Kydex molding if you are unfamiliar. Would back a better pod than plastic unless you are going to use some sort of injection molding process.
Jiveturkey3 is offline   Reply With Quote
Old June 13th, 2013, 09:49 PM   #9
firehawk
Live Action!
firehawk's Avatar
Originally Posted by Jiveturkey3 View Post
Www.knifekits.com
Can it be glued?
That is x2 the cost of ABS which I think should be more than enough. But thanks for highlighting that product as it might be something I can use in the future.
Old June 13th, 2013, 09:49 PM   #10
firehawk
Live Action!
firehawk's Avatar
Will keep that in mind, thanks!
Old June 13th, 2013, 09:50 PM   #11
firehawk
Live Action!
firehawk's Avatar
Livonia , MI 48150
Fax: (517) 787-6380
Driving directions
Will also keep this place in mind. Thanks!
Old June 13th, 2013, 09:55 PM   #12
Jiveturkey3
Can it be glued?
I have never tried to glue it but I would assume it could be done. The fact that a cookie sheet an an oven will allow it to be molded in any shape would help making pods. Also it can be heated with a gun and tweaked. The texture is ALOT like a dash. One side is smooth so I would assume you would need to scuff it to glue it.
Old June 13th, 2013, 10:41 PM   #13
JimNut
JimNut's Avatar
Sounds like your all set but another good place is Total Plastics in Rochester. They are off of Crooks just south of M59.
JimNut is offline   Reply With Quote
Old June 13th, 2013, 10:55 PM   #14
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
tfb plastics i order abs, poly, poly cast glass, ect by the pallet loads. top notch quaility great prices. why dont you make up a vac form tool and have a part sucked down. pm if you have questions
Old June 13th, 2013, 11:02 PM   #15
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Egay
H.o.r.e
Old June 14th, 2013, 05:32 AM   #16
cerial
Direct Drive FTW
cerial's Avatar
There is also an alro in grand rapids.
But, for small items like gauge pods just head to a truck stop and get a plastic mud flap. The plastic molds well while being thick enough to avoid cracking. You are going to paint it anyway so what do you care if the parent material is blue, yellow, white, or black.
This way if it does not turn out perfect the first time you don't need to bother the big suppliers for a 24" sheet.
Old June 14th, 2013, 06:08 AM   #17
BlooMule
Old School
BlooMule's Avatar
And your gauge pod will have the trucker girl on it!
-rw-rw-rw
Page generated in 0.28600 seconds with 73 queries
