Front/Rear Sway Bar Disconnect Offroad? Silver Lake - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 12th, 2013, 05:19 PM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default Front/Rear Sway Bar Disconnect Offroad? Silver Lake
2002 TJ 4.0L
2.5" RC Lift Front Quick Disconnects
Next week me and a large group of friends will be traveling to the west side of the state to stay at silver lake for almost a week. I am excited cause I will get to try out my 8 month old lift a little better on the dunes, I took it mudding once but thats it. I have read mixed reviews about disconnecting front or rear sway bar links or both, and I wanted to get some opinions.
Currently the jeep is lifted 2.5" and the wheels are spaced out about 2". I was thinking about disconnecting the front sway bar links when I am there for more articulation and possibly the rear but am unsure, what do you guys think. What are the pros and cons? Should I stick with both attached? Or Just connect one or the other?
Thanks!
Catnip 0_o is offline   Reply With Quote
Old June 12th, 2013, 06:47 PM   #2
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
You don't really need, or even want articulation in the sand. It just allows the tire that loses traction to dig deeper. Leave them connected.
Old June 12th, 2013, 06:50 PM   #3
2fst4you
2fst4you's Avatar
Leave them connected no reason to articulate in the dunes
Old June 12th, 2013, 09:29 PM   #4
GREASYHANDS
GREASYHANDS's Avatar
If your gonna jump stuff I would leave them on
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 12th, 2013, 09:33 PM   #5
mjvan44
GIT UP ON HER AN RIDE!!!
mjvan44's Avatar
If your going through the woops sideways disconnect
mjvan44 is offline   Reply With Quote
Old June 12th, 2013, 11:03 PM   #6
Wehan
Wehan's Avatar
If your quick disconnect are the pin through shaft variety I highly recommend getting some grade 8 bolts and replacing the pins with them. I can't count how many time my buddy has sheared off his pins on the dunes for his quick discos before he learned this trick. He drives a tj also.
Sent from my SCH-I535 using Tapatalk 4 Beta
Wehan is offline   Reply With Quote
Page generated in 0.25256 seconds with 41 queries
