flat skid at frame rails/ mml - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2013, 10:58 PM   #1
2fst4you
2fst4you's Avatar
Default flat skid at frame rails/ mml
In order to run a completely flat skid do I need both a body lift and lopro mount? If not which one does everyone prefer to run?
Lastly if I was to get a brown dog 1" MML could it be reused when I did a 5.3 motor swap
Thanks for the help!
-Cameron-
Old June 11th, 2013, 11:03 PM   #2
firehawk
Live Action!
firehawk's Avatar
You need to move the trans and motor up.
I have a flat skid but it is spaced down 3/4", in order to get it across the actual frame rails I would have had to get or make motor mounts to lift the motor at least an inch and then remount the custom trans crossmember up an inch or so but not sure if it would hit the tub, might need a slight body lift to do it. I am running an AW4/4.0 in a 94 YJ
Old June 11th, 2013, 11:05 PM   #3
2fst4you
2fst4you's Avatar
I plan to add a 1" MML with separate cross member just wondering if I need both a body lift and lopro mount or not
Old June 11th, 2013, 11:40 PM   #4
firehawk
Live Action!
firehawk's Avatar
Dont think you will need a body lift.
Old June 12th, 2013, 12:06 AM   #5
joe_jeep
welfare wheeler
joe_jeep's Avatar
what trans do you have? a flat skid with a 42rle and a 241or is real tough.
with a 5speed and a 231, it can be done. you will want a low pro mount and a bl for clearance, unless your gonna massage the floors.
brown dog sells mounts in 1", 1.25", 1.5", and 2.0" inch heights.
body lifts can be altered to many different heights for clearance.
what skid are u gonna run?
the brown dog mounts aint gonna work with a 5.3 without serious mods.
Old June 12th, 2013, 02:49 AM   #6
2fst4you
2fst4you's Avatar
I have an nv3550 5 spd trans. Got cha so I will need both? Don't really want to pound the tub. Looking at getting a 1" brown dog mml and jks 1.25 bl.
I will be making my own skid by buying some 1/4" flat stock. Ok thanks
Page generated in 0.22081 seconds with 41 queries
