tj occasional mis-fire - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2013, 11:05 PM   #1
99tj4banger
99tj4banger's Avatar
Default tj occasional mis-fire
I have a 2000 tj 4.0 5-speed.
It will occasionally have a mis or two usually in 3rd gear only under acceleration.
If I stomp on it, it runs fine. I have no codes or no pending codes and it does not do it all the time.
I put e3 plugs in it two years ago and im thinking those are most likely the issue.
Any suggestions?
99tj4banger is offline   Reply With Quote
Old June 10th, 2013, 09:19 AM   #2
Dannn
Dannn's Avatar
Pull the e3s and put in champion coppers. Start there, check the condition of the plug boots also.
Sent from my SCH-I535 using Tapatalk 2
Dannn is offline   Reply With Quote
Old June 11th, 2013, 04:42 PM   #3
99tj4banger
Update, I took out the e3's and put in auto lite app985 double platinums seems to run smoother and no missing so far.
Page generated in 0.18361 seconds with 32 queries
