hp dana 60 locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2013, 09:53 PM   #1
stuftmunky2k
stuftmunky2k's Avatar
Default hp dana 60 locker
swapping in a ford hp dana 60 front into the rig wondering what lunch box lockers people are running and how they hold up. im torn between the spartan or lock rite but the spartan doesnt say if it will fit in the hp axle dont see why it wouldnt. just seeing what you guys think.
stuftmunky2k is offline   Reply With Quote
Old June 10th, 2013, 07:34 AM   #2
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
its the spline count that counts, not hp or lp. fronts ends are 35 spline and rear 60 are 30 spline.
4x4xdodgeman is offline   Reply With Quote
Old June 10th, 2013, 07:36 AM   #3
big86inthestixx
big86inthestixx's Avatar
I got me a spartan in mine..works gud...
sended frum dis stoopid fone.
Old June 10th, 2013, 07:50 AM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
The sparty fits hp d60. I don't know what differences there are between any of them.
Old June 10th, 2013, 07:59 AM   #5
Spartan here. I ran a lock right prior and wore the teeth out causing it to slip.
Old June 10th, 2013, 09:23 AM   #6
I'm going to take a look at my lock-right next time I change fluid to see how the wear is on mine.
Old June 10th, 2013, 11:30 AM   #7
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Since you had both in your hand, did you see anything in the spartan that you think will make it last longer?
From what I've seen of the Lock Right and EZ locker in other applications.. well, I couldn't see anything different. Not sure how the Sparty or Aussie stacks up other than their manufactuerererer saying theirs is better.
Old June 10th, 2013, 11:33 AM   #8
Aussie didn't make a D60 last I checked. I liked my Aussie in my D30, more than my D35 lockrite I had.
Old June 10th, 2013, 11:38 AM   #9
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Yeah, I know different ones have different applications, but I don't remember much if any difference in D30 Lock Rights and EZ-lockers. Those were the only ones I had messed with before putting a sparty in a d60. The sparty was pretty much the same as the d30 lock right except bigger.
more importantly, did you actually modify a d35? ouch...
Old June 10th, 2013, 11:43 AM   #10
The biggest difference I noticed from having both was the pin design. I ran the lock right hard. V8 and 4ds. I also broke 3 stock stub shafts before getting 35 spline outers. I never broke the pins. Eventually the teeth wore down. I think I ran it 3 yrs. I even had the teeth edges recut and ran it a while longer before giving up on it. I didn't notice a difference in teeth.
The lock right pins are solid and the springs push against the pins. Spartan the pins are hollow and springs are inside the pins.
Old June 10th, 2013, 11:44 AM   #11
kkodet
kkodet's Avatar
There is no difference between HP and LP carriers. The difference will be 4:10 down and 4:56 up carrier break. However since you are using your carrier that won't matter.
Rumor is the Spartan is a newer design and a bit better than the others. I had an EZ locker for years in a dana 30 and loved it.
Old June 10th, 2013, 12:02 PM   #12
Yep, just the lock-rite and it paid for the locker when I sold it
Old June 10th, 2013, 12:30 PM   #13
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
bonjour
Old June 10th, 2013, 05:09 PM   #14
stuftmunky2k
ya couple buddies of mine run lock rite but they pussy foot around i have a pretty heavy right foot. probably just gonna pull the trigger on the spartan locker see how she holds up.
Old June 10th, 2013, 08:11 PM   #15
Nvrenuf
Nvrenuf's Avatar
I am running a Spartan in my HP60. I like the pin design and the access holes to hold the pins and springs in. its been in about 3 years now.
Page generated in 0.38033 seconds with 68 queries
