CJ stuff. Hood, Tank, Roll Bar, Top, Pedals, Heater, ETC. SOLD and RELISTED - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2013, 12:49 PM   #1
Swampbog
Swampbog's Avatar
Default CJ stuff. Hood, Tank, Roll Bar, Top, Pedals, Heater, ETC. SOLD and RELISTED
Everything is OBO, so if you see something you like and you think it's to high just let me know what your price range is.
Everything came off my 79 CJ5 excepted for noted.
I'm located in the Westland/Garden City area.
Up first is the factory fuse block/panel. The wires were cut back far enough where it's easy to splice in. $30 SOLD
Next is a fiberglass hood with stainless accessories. It's painted a dark green with some scratches and chips. $50 SOLD
I'll even through in the bumper stickers
Next is a worn Jeep brand softop with doors. It includes the bows and rods. The top has been repaired and does show it's age. I only put it on when I stored the CJ5 to keep snow and critters out of it. $40 SOLD
Next is a TV (transmission valve) rod assembly. This came off of an 83 CJ7 with a TF 999 trans. It includes the brackets and even the spring. $10 SOLD
Next is a gas pedal assembly $5 SOLD
Next is the windshield washer tank with the pump motor. I don't know if the pump works or not but the tank does have the AMC logo on it. ( I thought that was cool) $5 SOLD
Up next is a heavy duty tie rod and drag link assemply. The tie rod ends will need to be replaced but the tube is in good shape. $20 EDIT: this is for a wide track axle
I found theses buried in the back of my garage. The were for my 79 CJ5 and I know they won't fit my 83 CJ, other than that I don't know what years they will fit. They were never used and never taken out of the box until this picture. The rust is just surface rust from not having a good coverage of rust prohibitive applied from the manufacture. $10 takes both driver and passenger sides.
Last but not least is the custom roll cage I had done for my CJ5. It includes the seats shown and has mounts for a three point harness. The seats are mounted to the cage with some cross bars. I did notice that the lower part of the cross bar joints were not welded. The rusted out ares are all old CJ body sheet metal. Except in the flat plates connecting the B pillar and down tubes, that is from the factory roll bar and can be cut out. $100
Last edited by Swampbog; August 11th, 2013 at 04:52 PM. Reason: Sold some and relisted the others
Swampbog is offline
Old June 9th, 2013, 02:03 PM   #2
mr.cj
mr.cj's Avatar
still have the washer bottle? i will take it if you do
mr.cj is offline
Old June 9th, 2013, 03:02 PM   #3
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
Is the steering column tilt? If so I maybe interested
mudviper is offline
Old June 9th, 2013, 09:23 PM   #4
Swampbog
Swampbog's Avatar
Nope, sorry steering column doesn't tilt.
Swampbog is offline
Old June 10th, 2013, 03:10 PM   #5
Swampbog
Swampbog's Avatar
ttt
Swampbog is offline
Old June 10th, 2013, 03:28 PM   #6
Booster
Still have the hood? Gas pedel?
Booster is offline
Old June 10th, 2013, 03:44 PM   #7
Swampbog
Swampbog's Avatar
Yes both to hood and gas pedal.
Swampbog is offline
Old June 10th, 2013, 04:33 PM   #8
dmcjeep
dmcjeep's Avatar
To bad you are so far away or I would do a lot to help clear you out.
dmcjeep is offline
Old June 10th, 2013, 05:03 PM   #9
Swampbog
Swampbog's Avatar
It's only a 3 hour drive.
Would it help to say that later on I'll have some axles, engine,trans, transfer, and a solid beefed up frame going on the market?
Swampbog is offline
Old June 11th, 2013, 06:27 PM   #10
Swampbog
Swampbog's Avatar
ttt
Swampbog is offline
Old June 11th, 2013, 07:27 PM   #11
tcc
tcc's Avatar
Default Soft top and doors.
I"m in for the soft top and doors at 40 bucks. 989-745-3222 or PM. Pay cash and pick up.
tcc is offline
Old June 12th, 2013, 08:13 PM   #12
Swampbog
Swampbog's Avatar
ttt
Swampbog is offline
Old June 13th, 2013, 07:24 AM   #13
orionn
orionn's Avatar
Any damage on the steering wheel?
whats a good time to look at it?
Pm me your contact info please.
orionn is offline
Old June 13th, 2013, 07:35 AM   #14
Swampbog
Swampbog's Avatar
Steering wheel has worn/missing area (s) on it, about the size of a small hand.
Can't remember exactly right now.
I'll take pictures when I get home.
Any spelling errors are not the posters fault but the stupid phone that it was typed on
Sent from my SCH-I535 using Tapatalk 2
Swampbog is offline
Old June 13th, 2013, 05:45 PM   #15
Swampbog
Swampbog's Avatar
I wished the picture came out better. This is the best I got. It only has one area like this.
The steering wheel also has little hairline cracks on the backside.
ID:	107046   Click image for larger version
Swampbog is offline
Old June 16th, 2013, 06:17 AM   #16
Swampbog
Swampbog's Avatar
ttt
Swampbog is offline
Old June 17th, 2013, 02:05 PM   #17
Swampbog
Swampbog's Avatar
ttt
Swampbog is offline
Old June 21st, 2013, 06:43 PM   #18
Swampbog
Swampbog's Avatar
Weekend bump
Swampbog is offline
Page generated in 0.34380 seconds with 78 queries
