XJ: Compatible engines - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2013, 08:10 PM   #1
doug800
Default Compatible engines
Got a buddy with a 98 xj with a 4.0 automatic. Can anyone tell me What engines are compatible? He blew his up
doug800 is offline   Reply With Quote
Old June 12th, 2013, 08:52 PM   #2
burnsie
burnsie's Avatar
He has to make sure it's for an XJ. The motor mounts are different for wranglers and ZJ's. I'm pretty sure a 99, 00 motor should work just fine just need to make sure that its a motor with a conventional distributor not coil packs. Hope this helps. Good luck!
burnsie is offline   Reply With Quote
Old June 15th, 2013, 05:16 PM   #3
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I think a 91-99 from wrangler or Cherokee will work. If you don't mind swapping manifolds, accessories, or motor mount brackets.
Page generated in 0.13660 seconds with 32 queries
