TJ: Chasing a noise..need suggestions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2013, 05:36 PM   #1
Captain_Morgan
Carnival Awaits Us
Captain_Morgan's Avatar
Send a message via Yahoo to Captain_Morgan
Default Chasing a noise..need suggestions
Ive got a 97 wrangler.
specs:
2.5l, 5 speed
4" skyjacker suspension lift(shocks, springs, LCA's, sway links, adjustable front track bar and steering stabilizer, 1" t-case drop, crown extended brake lines, drop pittman arm.)
Note that I'm not running a sye although Ive bought one and a tom woods driveshaft. put over 10k on it since the lift.
Noise like a knock or pop when I start off in first in 2 hi only, not 4hi or 4lo. does it like 3-5 times each time i start off from a stop.
Ok, so I noticed this noise a couple weeks ago and its been getting worse latley. I got it on a lift and checked u joints and found both outers in the front were bad so I replaced them but that didnt get rid of it. Yesterday I dropped the front driveshaft and checked those also. One was great and the other was iffy. drove it without the shaft and the noise is still there.
I figured I'd ask on here and see if anyone has any insight into what it could be.
Captain_Morgan is offline   Reply With Quote
Old June 6th, 2013, 05:38 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
Upper control arm bushing in the rear
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old June 6th, 2013, 05:48 PM   #3
Toyfish
Toyfish's Avatar
X2
Sent from my DROID X2 using Tapatalk 2
Old June 6th, 2013, 11:51 PM   #4
99tj4banger
99tj4banger's Avatar
Try taking a look at the front body to frame mounts right behind the front tires. A buddy of mine had a weird clicking noise he only got from taking off or hitting bumps. It was a body mount that had rusted just enough to let the nut on the inside free from the tub.
99tj4banger is offline   Reply With Quote
Page generated in 0.27209 seconds with 35 queries
