ZJ: Grand Cherokee Rough Start + Other Problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2013, 05:28 PM   #1
Sil3ntP8nd8
Photographer
Sil3ntP8nd8's Avatar
Send a message via Skype™ to Sil3ntP8nd8
Default Grand Cherokee Rough Start + Other Problems
Hopefully this video should work:
https://www.facebook.com/photo.php?v...79681180296037
Throws up all of my coolant once in a while, I overheat but I blame it on my fan clutch or a leak in the radiator/water pump. Rough idle and it usually dies right after unless I keep on the gas. Power steering cuts in and out at times. I replaced the oil pressure sender a while back hence why it doesn't read anything. There is a check engine light but its from me not having an O2 sensor because I don't have a cat.
Sil3ntP8nd8 is offline   Reply With Quote
Page generated in 0.12735 seconds with 26 queries
