Tire size - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2013, 01:23 PM   #1
Ebrown
Ebrown's Avatar
Default Tire size
I have a 1999 Xj Sport, The stock tire size is 225X75X15, Can I run 235X75X15 with out any rubbing ?
The thing is I plan to lift my xj 3" and have ran out of time before I go caming to the U-P and don't have the time to put it on, I will be pulling a 2013 Jayco 10Fd with about 350 lbs hitch weight!
Ebrown is offline   Reply With Quote
Old June 5th, 2013, 02:22 PM   #2
grocerygetterxj
Yes, you can run up to a 30x9.5x15 with only minor rubbing in the front at full turn however they recommend a 2 inch lift at that size. I had 30's and a 2" BB and pulled a 2900 lbs camper all over. Not perfect but doable.
grocerygetterxj is offline   Reply With Quote
Old June 5th, 2013, 02:35 PM   #3
kickstand
circling the drain
kickstand's Avatar
I ran 235/75's with no lift just fine on a 98.
Old June 5th, 2013, 09:47 PM   #4
skife
skife's Avatar
I ran 30s with no lift very slight rubbing at full lock.
Page generated in 0.15055 seconds with 35 queries
