CJ: Welding an engine block - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2013, 09:09 AM   #1
willdorf
Dude VonDudenstein
willdorf's Avatar
Default Welding an engine block
The block on my inline 6 cracked. Wondering if anyone knows what kind of rod I will need to weld it?
willdorf is offline   Reply With Quote
Old May 31st, 2013, 09:25 AM   #2
crazymanme2
I've used super missle with some pre heat with good results.
crazymanme2 is offline   Reply With Quote
Old May 31st, 2013, 09:34 AM   #3
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
isn't that generally something you don't do with a cracked block????
Old May 31st, 2013, 09:48 AM   #4
willdorf
Dude VonDudenstein
willdorf's Avatar
Generally you don't. But I want to try to fix it before i get another block or whole motor.
Old May 31st, 2013, 09:49 AM   #5
willdorf
Dude VonDudenstein
willdorf's Avatar
and thanks Crazyman, any specs on that? or is just a brand name?
Old May 31st, 2013, 06:42 PM   #6
Wramblerguy
Wramblerguy's Avatar
Is it just cracked in a water jacket or??
3rd generation jeeper
Wramblerguy is online now   Reply With Quote
Old May 31st, 2013, 07:15 PM   #7
pitbull2332
pitbull2332's Avatar
You need a nickle rod to weld cast iron. To do it you need to preheat the block to 550 degres and cool it slow. I usually wrap it in a welding blanked and let it be. On the crack v it out good and drill an 1/8" hole at the end of the crack to stop it from spreading. I know this is not what you were looking for being an assembled motor, But it is the proper way to weld cast iron. also be aware, welding can arc between your bearings in the crank and pistons to cylinders ect.
pitbull2332 is offline   Reply With Quote
Old June 1st, 2013, 06:49 PM   #8
skife
skife's Avatar
so keep your ground as close as you can to the spot you're welding.
also, if it's just a water jacket you can use JB weld, buddy of mine had an old 79 blazer with cracked water jackets that someone just plastered JB weld all over the side of the block, it was compleatly fine until you started beating on it alot and it'd leak a little bit.
Old June 2nd, 2013, 07:20 AM   #9
Booster
Aim no weirder had a friend weld he use nickel rod lasted over 20years.GOFor it
Booster is offline   Reply With Quote
Old June 2nd, 2013, 07:51 PM   #10
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I wonder if you would be better off brazing or silver soldiering it than welding it. To weld it correctly you have to get it hotter than I would prefer to get an assembled engine.
Old June 2nd, 2013, 08:26 PM   #11
cj65
cj65's Avatar
I've welded three blocks while in the truck. I used a high nickel content rod. I never did any preheating. I did drill small holes at the ends of the crack and all has been fine. They all are on the road still. One was in father in laws dodge. His cummins had a three inch crack just above the oil pan. That one was a pita due to oil seeping thru the crack. Was very hard to get it clean enough to weld it. If your not sure about welding it I'll help you out if need be.
Old June 3rd, 2013, 08:22 AM   #12
willdorf
Dude VonDudenstein
willdorf's Avatar
Thanks for all the advise guys. Does anyone have any specific specs for the rods? Like what numbers and stuff? Just want to make sure I get the correct amount of nickel and what not so it is a good weld and will hold for a bit. Granted this jeep is my toy, but I don't want to be redoing it. And it is cracked below the exhaust manifold, far enough down to just have to pull off the fender and the exhaust to get to it. Made the mistake of leaving water in it over the winter.
Old June 3rd, 2013, 08:39 AM   #13
knaffie
knaffie's Avatar
Call crown alloys and ask them which alloy to use.
Sent from my DROID RAZR using Tapatalk 4 Beta
Old June 3rd, 2013, 08:55 AM   #14
willdorf
Dude VonDudenstein
willdorf's Avatar
Ok thanks alot Knaffie
Old June 3rd, 2013, 08:55 AM   #15
dreezy
Haggard Fab
dreezy's Avatar
Braze it, disassemble it and weld it, or replace it.
Old June 3rd, 2013, 10:45 PM   #16
chadcooper55
If you don't preheat it and arc weld it you are asking for problems. To arc weld cast you must preheat, weld, peen to distress, post heat and cool very slowly. If you do not do that you are asking for stress cracks and you completely wasted your time. I would be curious to see how some a2 bronze tig rod would work If you can get it clean. A softer more pliable fill rod wont stress the cast as much. If you insist on arc welding I would pull the belt off so you don't run a dry water pump and fire the motor up until it is good and warm (borderline over heating). Then I would weld and peen with a center punch to de stress it after every rod. After I was done welding I would fire then motor up and let it warm up a bit and shut it back down quite a few times so it cools very slowly. Also as somebody else stated make sure to drill the ends of the crack or it will continue to crack. A good even preheat with a very slow cool down is very very important and don't let anybody tell you otherwise. It is especially important because you can't get it to the full temp that you really should have to repair it correctly.
Page generated in 0.36453 seconds with 71 queries
