5.3 OR 4.3 swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2013, 07:43 AM   #1
holubikj
holubikj's Avatar
Default 5.3 OR 4.3 swap
has any one completed one of these into an xj. can you run the 5.3 with a 700r4 or 350 trans. and does the hood still fit with either
holubikj is offline   Reply With Quote
Old May 31st, 2013, 05:44 PM   #2
Wramblerguy
Wramblerguy's Avatar
Why would you swap a 4.3 in a jeep that hat a 4.0 as an option I have no idea
I vote 5.3 and I've seen it done where the hood shuts I believe you have to use the car intake thou
3rd generation jeeper
Old June 10th, 2013, 08:21 AM   #3
Dannn
Dannn's Avatar
5.3 all day long. Just finished a 6.0 swap in my tj. Best mod ever.
Edit: run a 4l60e... much easier to adapt and tune. 700r4 requires a tv cable which may become an issue if you get a dbw 5.3.
Sent from my SCH-I535 using Tapatalk 2
Dannn is offline   Reply With Quote
Old June 10th, 2013, 09:36 AM   #4
swampjeep
Swamp Stomper
swampjeep's Avatar
did you get teh factory gauge cluster to work with the 6.0, if so how?
thanks, also thinking of a 5.3 swap into my TJ
swampjeep is offline   Reply With Quote
Old June 15th, 2013, 07:47 PM   #5
mr crawl
Mr Crawl
mr crawl's Avatar
for my money I would keep the 4 liter, they are much easier to work on in a tight area, more reliable, and there are plenty of performance mods if you want more power, just my two cents
mr crawl is offline   Reply With Quote
Old June 15th, 2013, 08:21 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
There are a few on here that did the LS swap. If I had one a few years ago, I wouldn't have done a small block swap in my XJ.
Page generated in 0.23462 seconds with 42 queries
