The FWD 5.3L LS4 oil pan to LQ9 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2013, 05:32 AM   #21
Cartman
Can't lose with 42s
Cartman's Avatar
CTS-V pan is another low profile factory option, probably not as plentiful as the FWD ones though
Cartman is offline   Reply With Quote
Old June 1st, 2013, 10:05 AM   #22
chevotass
chevotass's Avatar
just ordered the one on ebay. $99 shipped. looks like I get everything I need. and I can use my truck dipstick. now I see the sensor on the bottom of the pan in the ls4. is it a different style connector than the truck pan sensor on the side? the corvette and fbody pans are 200- 300. fawk that.
Old June 1st, 2013, 07:11 PM   #23
pigfat
GONE COMMANDO
pigfat's Avatar
hell yeah and with only like a 1/2" difference. well worth the extra work on the inspection cover. Drove mine around today with no problems at all.
pigfat is offline   Reply With Quote
Old June 1st, 2013, 07:12 PM   #24
pigfat
GONE COMMANDO
pigfat's Avatar
Yeah its totally different but I don't even use mine, if you use yours you can get the pigtail and splice it. Don't forget that the LS4 pan takes a PF48 OIl filter with the bypass built in.
Old June 1st, 2013, 07:16 PM   #25
pigfat
GONE COMMANDO
pigfat's Avatar
Originally Posted by jbsjunk View Post
Obviously no problems with the starter fitting right since the FWD model mounts on the front side of the engine. The pics are perfect.
correct no problems with starter, its a direct bolt in. other than there is one hole in the truck pan that's not drilled in the block of the truck block and the Ls4 has a hole drilled in the pan. I just silicone it. good to go.
Old July 1st, 2013, 07:49 PM   #26
chevotass
chevotass's Avatar
put my new pan on. so much more clearance. now I get to rebuild my skid plate and get rid of the 4" drop down I had for the truck pan. only issues I have found is the 2 rear pan bolts are way to long. so I have to source 2 new shorter bolts. and the cap on the side of the oil filter for I think the remote cooler lines on some vehicles. they are different sizes. My oil pressure sensor is in that cap. so I have to drill and tap the new one instead of just bolting the one from my truck pan on. just a heads up to others. they are close. but not the same size.
Old July 1st, 2013, 07:54 PM   #27
pigfat
GONE COMMANDO
pigfat's Avatar
excellent info, glad it worked out for you, was pretty cool for me to I got lucky and had the Bulls but I did have to rework my inspection play area and I did have to end up short in the dipstick but a half inch and I save 300 bucks
Old August 7th, 2013, 07:14 AM   #28
chevotass
chevotass's Avatar
could not use this for my app. I have my pan up for sale
Old August 7th, 2013, 07:32 AM   #29
pigfat
GONE COMMANDO
pigfat's Avatar
Why, it wouldn't fit?
Old August 7th, 2013, 09:45 AM   #30
chevotass
chevotass's Avatar
Lost 3" of uptravel with the front of pan hanging lower than truck pan. Front axle yoke hits.
Old August 7th, 2013, 10:56 AM   #31
pigfat
GONE COMMANDO
pigfat's Avatar
Ah man that sucks
Page generated in 0.33297 seconds with 56 queries
