The FWD 5.3L LS4 oil pan to LQ9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2013, 11:03 PM   #1
pigfat
GONE COMMANDO
pigfat's Avatar
Default The FWD 5.3L LS4 oil pan to LQ9
In case anyone wants to know. The fwd version of the 5.3L, the LS4 oil pan will fit on a rwd LS engine. I put the pickup tube and windage tray and oil pan on my lq9. Its pretty low profile and holds over 6qts of oil. Got it free. sure beats the long truck pan.
pigfat is offline   Reply With Quote
Old May 30th, 2013, 11:18 PM   #2
Toyfish
Toyfish's Avatar
Woohoo maybe now u can go wheeling without a oil leak!
Sent from my DROID X2 using Tapatalk 2
Old May 31st, 2013, 11:46 AM   #3
pigfat
GONE COMMANDO
pigfat's Avatar
Yep Fish and hope to not crack this one. I lost almost 3" of length which is pretty sweet.
Old May 31st, 2013, 12:39 PM   #4
chevotass
chevotass's Avatar
Pic or part #. I need a pan
Old May 31st, 2013, 01:01 PM   #5
pigfat
GONE COMMANDO
pigfat's Avatar
Guy on ebay has one with windage tray and pickup tube for 80 bucks!! Search for ls4 oil pan. Can't get a pick up til later but my oil pan now is level with my trans pan.
Old May 31st, 2013, 01:33 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
GM Part #'s from 09 Impala SS
Oil Pan 12616129
Pickup 12594652
Windage/Deflector 12569042
Dipstick tube 12569046
Dipstick 12569045
Filter AC Delco PF48
Seal, Oil pump 12584922 (comes with pickup)
Old May 31st, 2013, 05:26 PM   #7
jbsjunk
Little Member
jbsjunk's Avatar
This is good info.
Old May 31st, 2013, 06:09 PM   #8
Any benefit over, say, the H3/hot rod pan, or a standard F-body? I need to swap out the goofy pan on my LS2 (trailblazer ss pan with the forward sump and hole through it for the axleshaft.)
Old May 31st, 2013, 10:26 PM   #9
pigfat
GONE COMMANDO
pigfat's Avatar
Heres a couple shots of the Ls4 pan.
One thing I will add is that I have to redo my inspection cover now as the rear of the pan is different than the truck pan. Not a huge amount of work there but way better than dumping 365 for the f body or corvette pan.
Old May 31st, 2013, 10:30 PM   #10
pigfat
GONE COMMANDO
pigfat's Avatar
THe only benefit I see is that it holds 6qts of oil, No real baffles in the pan but it is almost 3 inches shorter than the truck pan. If I was faced with having to purchase a pan I woulda bought the corvette pan but it was free and seeing I broke my pan the weekend before I got this one. It was perfect.
Old May 31st, 2013, 10:34 PM   #11
My CJ6 is only going to be a street rod/drag toy, so I haven't been worried about oil control that off road Jeeps need to think about..
Old May 31st, 2013, 10:44 PM   #12
pigfat
GONE COMMANDO
pigfat's Avatar
heres before and after.
Old May 31st, 2013, 10:45 PM   #13
KillaGrn
KillaGrn's Avatar
Is your Oil PSI any different? Higher/Lower??
KillaGrn is offline   Reply With Quote
Old May 31st, 2013, 10:46 PM   #14
pigfat
GONE COMMANDO
pigfat's Avatar
and also the windage tray kinda acts as a baffle so sounds like youll be good. Ill know soon enough when I get back from Golden Mountain If I don't get cavitation there then I should be good.
Old May 31st, 2013, 10:47 PM   #15
pigfat
GONE COMMANDO
pigfat's Avatar
I switched to synthetic oil this time so my idle oil pressure is slightly lower but nothing other than that.
Old May 31st, 2013, 10:56 PM   #16
pigfat
GONE COMMANDO
pigfat's Avatar
one other thing, my truck dipstick and tube was spot on as far as oil lever. 6 qts reads full.
Old May 31st, 2013, 11:03 PM   #17
pigfat
GONE COMMANDO
pigfat's Avatar
curious as to why you asked, have other people experienced low pressure after this swap?
Old May 31st, 2013, 11:35 PM   #18
chevotass
chevotass's Avatar
thanks for the tip. I have been putting off buying a $300-350 aftermarket or find a used fbody pan for $200. what a ripoff.
this will be my next purchase. hopefully this week.
Old June 1st, 2013, 12:31 AM   #19
Wehan
Wehan's Avatar
The drain plug looks funny on the side, way to think outside the box.
Wehan is offline   Reply With Quote
Old June 1st, 2013, 01:56 AM   #20
jbsjunk
Little Member
jbsjunk's Avatar
Obviously no problems with the starter fitting right since the FWD model mounts on the front side of the engine. The pics are perfect.
Page generated in 0.45165 seconds with 83 queries
