Dammittttt! RUST - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2013, 04:00 PM   #61
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
Originally Posted by Bones View Post
you forgot about the years or free storage and work space at "friends" houses. I can't even pull that off.
I don't know, I'm just an aquaintance not really a friend per say.............but you own some toys that you would be more then welcome to store at my place. Just leave the keys.
Old May 31st, 2013, 06:32 PM   #62
XXXJ
Desert Rat
XXXJ's Avatar
Originally Posted by skife View Post
then spend double the time to remove cosmoline from spaces you cant get to.
Example: I took some rotors to be turned. I had a spare set of fronts turned. I was working on the rears. So back with the right rotors to be turned, the fronts to be saved for later.
So, I sprayed the rotors with "Cosmoline Weathershed". Bagged and tagged for later. When later came, a little solvent (I think I used acetone) wipe down and they were clean and good to go. It is not like the bars you had to heat up.
I've been spraying any bare metal susceptible to rust.
Smells like army
Old May 31st, 2013, 06:53 PM   #63
Originally Posted by welderboyjk View Post
As mentioned in a previous post only use wd40 for cleaning. It's too light of an oil for machine protection. It will dissolve any oil that you do have and flush it away. It will then "flash" off/evaporate and leave NOTHING behind but a bare metal surface which will rust quicker than you can say sumbitch.
If you've only got a little surface rust I would not use scotchbrite on my machines. Grab a rag, soak it in way oil and start scrubbin. You may be amazed how easily it(rust) comes off. Be careful to NOT get/leave any oxide on the ways of the machine(s).
I've walked into the shop before and had the "Oh what the fukc !!!" moment. As you are probably more than well aware now if it's been cool and then the temp suddenly rises along with the humidity large chunks of cast iron will sweat profusely.
P.S. get real way oil and don't sub. engine oil either. Something about engine oil encapsulating water and letting it set on the machine surface under a layer of oil
Good luck with your cleanup. It sucks, I know.
As I said before, I'm using way oil. A rag will not do it, it needs the extra umph from the scotchbrite. I should have taken pics, this is way worse than a little brown here and there. I've had machines in my garage for the past 15 or so years, same address, same everything, with some mild surface rust from time to time but this is the first time it has attached to EVERYTHING.
I hate cosmoline. And I can't even imagine putting cosmoline on everything in my garage. FWIW, we have customers who have told us if we ever ship with cosmoline on our products again, it will be the last time they will buy from us.
Old May 31st, 2013, 07:44 PM   #64
DuffMan
Your Message Here
DuffMan's Avatar
Great stuff. NOT easily cleaned off.
I coated the underside of my truck with it and sprayed inside all panels/nooks/crannies with it. Inside of frame on truck & TJ are coated in it.
Old May 31st, 2013, 09:19 PM   #65
Hehehe, that stuff does cling. My mill came from my grandpa's garage after he passed away. He was a bit lazy and never cleaned all the cosmoline off it. It was in his garage for 25 years or so, and all the non-work surfaces were still completely covered with it.
Old May 31st, 2013, 09:47 PM   #66
Bones
Bones's Avatar
deal, you can store the freightliner and new race truck, you just have to fix what is broken and deliver it to the TREC races...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 31st, 2013, 10:34 PM   #67
BlooMule
Old School
BlooMule's Avatar
I'm glad I buy my tools pre-rusted...
Oh, and I'm still wondering what a guy who lives in his parent's basement is doing with Crisco....
-rw-rw-rw
Page generated in 0.21910 seconds with 43 queries
