Dammittttt! RUST - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2013, 09:22 PM   #1
Default Dammittttt! RUST
Spent last night in the garage and the humidity got really bad. Just went out to the garage & ALL of my equipment has a layer of rust on it since last night. Bridgeport, Lathe, bandsaw, table saw, jointer, all are completely rusted on all ways & machined surfaces. I imagine there is other stuff too once I start looking.
I can see hours with scotchbrite & oil to save them. If you haven't checked your equipment, you should.
Old May 29th, 2013, 09:26 PM   #2
dreezy
Haggard Fab
dreezy's Avatar
Sounds like its time to add ac to the shop.
Old May 29th, 2013, 09:28 PM   #3
vr
vr's Avatar
It's seasoning!
vr is offline   Reply With Quote
Old May 29th, 2013, 09:30 PM   #4
Yeah, I had that over the winter. My lathe is loaded up with a good layer of way oil, but my mill and drill need to be coated, and I don't know what to do with my steel work/welding table. Don't really want it coated with wd40 or something but it flash rusts...
Old May 29th, 2013, 09:36 PM   #5
I keep a pretty good eye on it because slight rust can happen without seeing it. This on the other hand looks like it was freshly spray painted overnight. Headed out during intermission to start scrubbing.
Old May 29th, 2013, 09:37 PM   #6
Nvrenuf
Nvrenuf's Avatar
I've had good luck putting a couple of old ceiling fans in the barn. Keeps the air moving and temps equal.
Old May 29th, 2013, 09:39 PM   #7
I was out last night & pulled a gatorade out of the fridge. It was literally steaming like dry ice.
Old May 29th, 2013, 10:37 PM   #8
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I keep the doors closed when there is drast temp changes. I was out in shop tonight and it was still 60 in there and dry. I turned the furnace on and brought it up to 72. It's still dry in there. But over the past few years I have gone out there to a wet shop. It sucks when that happens.
Old May 29th, 2013, 10:47 PM   #9
Sandals
Fucking Zen as Shit
Sandals's Avatar
I use Bostik Top coat and then 100% carnuba wax on all the cast iron parts of table saw, lathe, drill press table, mortiser, jointer etc.
I clean and reapply once a year and it seems to have stopped the rust issue
Old May 29th, 2013, 10:49 PM   #10
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
A simple paste wax works wonders on machine surfaces. Another odd but effective option is crisco. Non toxic or dangerous, quick coat of brake clean removes it. Have to be careful not to load up machine ways with it thought, it can gum things up.
I'm the man in White.
Old May 29th, 2013, 10:49 PM   #11
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Skooter_Built View Post
A simple paste wax works wonders on machine surfaces. Another odd but effective option is crisco. Non toxic or dangerous, quick coat of brake clean removes it. Have be careful not to load up machine ways with it thought it can gum things up.
Parents basement pretty humid?
Old May 29th, 2013, 10:51 PM   #12
That's a good idea. Definitely worse on the cast iron parts. What sucks is my table saw and jointer are buried way back because I'm not using them right now. I see at least an hour to dig them out and rub them down. I got the lathe & bandsaw done during the last intermission. Started on the Bridgeport & it's terrible. It's crazy. I left a dust pan on the Bridgeport table last night & it was clean underneath.
Old May 29th, 2013, 10:52 PM   #13
Skooter_Built
The garage is, where my tools are at
Old May 29th, 2013, 11:18 PM   #14
XXXJ
Desert Rat
XXXJ's Avatar
spray with Cosmoline
Old May 29th, 2013, 11:36 PM   #15
skife
skife's Avatar
then spend double the time to remove cosmoline from spaces you cant get to.
Old May 29th, 2013, 11:36 PM   #16
skife
skife's Avatar
you could always go start a fire in your woodstove when it gets really wet, usually fire drys things out.
Old May 29th, 2013, 11:40 PM   #17
Elvis13
The condensation in my garage drives me crazy, it looks like someone put a garden hose in my toolbox drawers in the mornings sometimes.
Cover all your machines with dustpans, problem solved.
Old May 30th, 2013, 01:27 AM   #18
BadMoonRacing500
Freedom isn't Free
BadMoonRacing500's Avatar
Clean your roof and sofit vents?
BadMoonRacing500 is offline   Reply With Quote
Old May 30th, 2013, 06:33 AM   #19
Were you outside Tuesday night? The humidity and temperature change was amazing. This did not happen over time and I didn't notice it. It happened in a 24 hour period. The bad part is I didn't think about it and predict it. If I had, I could have fired up the furnace for the night. There is nothing covering the roof and I have sofit vents.
This is only the second time I have ever had this happen and this is the worst by far. Previously it was minor.
No wood stove. Natural gas furnace.
Old May 30th, 2013, 08:21 AM   #20
clarkstoncracker
lol
clarkstoncracker's Avatar
Page generated in 0.29718 seconds with 82 queries
