ZJ: Weird woble from rear. Vauge steering? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 27th, 2013, 10:03 PM   #1
Badmunky
Badmunky's Avatar
Question Weird woble from rear. Vauge steering?
Ok so on Saturday I bout my wife a 1998 Jeep Grand Cherokee.
It seamed to drive good when I test drove it but now she is complaining that the rear of the truck wobles or sways left to right as she drives.
What could be causing this?
She is also complaining that the steering feels lose, but it feels like most Jeeps with a solid front axle to me. Its a bit vauge, but its not a sports car.
My plan is to pull the wheels off tomorrow and inspect it.
Thanks fo the help.
Badmunky is offline   Reply With Quote
Old May 27th, 2013, 10:46 PM   #2
Toyfish
Toyfish's Avatar
Could be a worn rear track bar
Sent from my DROID X2 using Tapatalk 2
Old May 28th, 2013, 08:14 AM   #3
Badmunky
Badmunky's Avatar
Yeah thats what I think it is to.
If it stops raining Im going to get under it and check it out.
Old May 28th, 2013, 09:10 AM   #4
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Bad rear track bar or bad shocks.
Old May 28th, 2013, 09:13 AM   #5
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
broken belt in a rear tire?
hawkscj5 is offline   Reply With Quote
Old May 28th, 2013, 09:19 AM   #6
Badmunky
Badmunky's Avatar
All 4 tires are new. It seams to only do it bad on rutted roads, and when you go over pot holes and bumps.
If it ever stops raining Ill pull the wheels and see I can find any thing wrong with it.
Sorry if some of my questions are noob questions. But Im new to 4x4s. Not new to working on cars thou.
Thank you guys for the help!
Old May 28th, 2013, 11:09 AM   #7
skife
skife's Avatar
check the lug nuts
Old May 28th, 2013, 11:25 AM   #8
Badmunky
Badmunky's Avatar
There tight.
I just drove it again and I dont see any thing wrong with it.
Going to pull the wheels and give it a good look over shortly. Its almost dry out side now.
Old May 28th, 2013, 11:52 AM   #9
ajmorell
Worn UCA's out back will cause wandering too, when mine went bad it would shift around when I was on/off the gas
Old May 29th, 2013, 09:11 AM   #10
Badmunky
Badmunky's Avatar
I could not find any thing lose or worn out.
So I took it to a shop and had them look at it and they said there is nothing wrong with it.
I think its just that she is used to driving a sports car.
Page generated in 0.28436 seconds with 53 queries
