TJ: Crank position sensor not setting properly - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 25th, 2013, 08:04 AM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default Crank position sensor not setting properly
02 auto TJ 4.0
Long story short, my CPS failed me last July and I bought an aftermarket one. Since then I will get misfire and lag at random times, usually at 2800+rpms or hill inclines. I did some research and found that aftermarket CPS can cause this so I went to the dealer and got a MOPAR one. Well when I went to pull the old one out I noticed the little paper spacer was still on it, you know the ones that's supposed to get sheared off after first startup...
Anyways, I installed the new one and first start this morning I took a lot of cranks to start, I'm wondering if it isn't set properly, anyone else have this problem? How do I go about adjusting it, not much room to work with..
Thanks
Catnip 0_o is offline   Reply With Quote
Old May 25th, 2013, 08:15 AM   #2
tom tom
tom tom's Avatar
How many miles ? From what your saying I am leaning toward a fuel pressure. Like a fuel filter, or Fuel pump not keeping up.
tom tom is offline   Reply With Quote
Old May 25th, 2013, 08:32 AM   #3
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Already replaced the TPS, cleaned throttle, IAC, Cam Sensor, Fuel Pump w Regulator (spectra premium), plugs, Ignotion coil, I am certain it is the CPS. Before I replaced it with the mopar unit yesterday it would start right up but when the motor got hot would randomly misfire. Your CPS can undergo thermal failure. Now with the new and better CPS installed, it has longer crank time. Should I just pull the spacer off and install it?
Oh and 145k miles
Old May 25th, 2013, 11:25 AM   #4
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Anyone??
Old May 26th, 2013, 05:55 AM   #5
RADRICK
RADRICK's Avatar
I was told by a jeep dealer tech to replace the cam & cps sensors as a pair so they relearn properly.
Old May 26th, 2013, 05:57 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
pull the cps, look at the cam gear. the cps units that fail, often take out the cam gear.
turn the engine over to top dead center. and set to zero at the timing marks.
take the top cover off the cps unit, it should have an alignment pin hole in it.
find a nail or punch that fits it tightly. drop it in at the point. it will tolerate up to 7 or 8 degrees off.
it will run better the closer it to zero is. the dealer can sync it if you cant get it right.
if you can get it within a couple degrees of zero it will run fine.
your jeep is a 2002, mine is an 05, they have different cps units.
im assuming your install procedure is similar.
Old May 28th, 2013, 09:50 PM   #7
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
I'm afraid I'm really confused about everything you just said :p
Old May 29th, 2013, 12:52 AM   #8
joe_jeep
welfare wheeler
joe_jeep's Avatar
i was assuming you meant cam position sensor, cause they commonly fail, sorry.
when you are gonna start it. turn the key forward to the run position for 5 seconds, then start it.
jeeps do have issues with the drain back valve in the fuel system. takes a few seconds to prime the system again.
all the fuel leaves the fuel rail and drains back to the tank. if thats the issue it will start very quickly after the rail is pressurized again.
my old tj did that. give that a try.
Old May 30th, 2013, 06:42 PM   #9
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
haha yes a misunderstanding xD
for the first few days after replacing the crank sensor with the MOPAR one it would have the longer crank and occasionally sputter after start for a few seconds but i noticed last night and today it is starting to fix itself. Only cranks about 2 times before it starts and the sputter is going away :) hopefully my misfire on highway speeds is completely gone!
Old May 30th, 2013, 06:49 PM   #10
joe_jeep
welfare wheeler
joe_jeep's Avatar
cool!
Page generated in 0.24210 seconds with 53 queries
