best automotive electrical connection? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 24th, 2013, 10:51 PM   #1
adamzr2
numero douce undela
adamzr2's Avatar
Default best automotive electrical connection?
without soldering what do you think is the best process to connect wires or splice into wires in a car?
curious as to what all the old timers use
adamzr2 is offline   Reply With Quote
Old May 24th, 2013, 11:09 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
I use non-insulated(bare metal) terminals and adhesive lined shrink tube most of the time. I will use fully insulated terminals on positive wires with disconnects, like spade or bullet terminals.
Old May 24th, 2013, 11:13 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Twist and tape
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old May 24th, 2013, 11:13 PM   #4
tweak177
Say what?!?
tweak177's Avatar
Soldering and heat shrink is the best, end of story.
tweak177 is offline   Reply With Quote
Old May 24th, 2013, 11:42 PM   #5
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I like to use the butt connectors that heat shrink and solder when heated.
Old May 24th, 2013, 11:43 PM   #6
dreezy
Haggard Fab
dreezy's Avatar
My old man uses butt connectors packed with grease.
Old May 25th, 2013, 12:23 AM   #7
Elwarpo
The Warped One
Elwarpo's Avatar
I use the 3m connectors with the shrink tube already on the connector. With some final shrink wrap on top for interior and solder with shrink wrap for outside.
Elwarpo is offline   Reply With Quote
Old May 25th, 2013, 12:49 AM   #8
adamzr2
numero douce undela
adamzr2's Avatar
I know soldier is best, but sometimes that's not a option, what if you want to be able ton remove the component
Old May 25th, 2013, 06:52 AM   #9
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
weatherpak or metripak connector.
wrath is offline   Reply With Quote
Old May 25th, 2013, 07:51 AM   #10
Mr.Green
I can levitate!
Mr.Green's Avatar
Side cutters.
Old May 25th, 2013, 04:07 PM   #11
mschaffer66
mschaffer66's Avatar
Side cutters.
Dikes.
But yeah the point of making an electrical connection is so that its a secure connection. If you are using some sort of crimp on connector it should be crimped to the point where you are cutting some wire to remove it. If not you did a shitty job crimping it on or chose the wrong size connector. If you want something that is temporary and easy to undo maybe then twisting and tape or wire nuts is the way to go.
Personally I like to solder stuff, but when I get lazy and want to just be done I use the crimp ons.
Old May 25th, 2013, 04:09 PM   #12
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by mschaffer66 View Post
Dikes.
Or a proper plug.
Old May 25th, 2013, 06:41 PM   #13
cerial
1200PSIg Double acting
cerial's Avatar
Twist, bend, solder, shrink. Only if you need to.
Replacing the entire wire connection to connection for best results and less drop is the right way with minimal cost.
Old May 25th, 2013, 06:55 PM   #14
tonka toy
It's got a HEMI!
tonka toy's Avatar
Scotch locks FTW!!!!
I use a crimp on connector with shrink tube when ever I can.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old May 25th, 2013, 07:03 PM   #15
JimNut
JimNut's Avatar
The crimping tool is just as important as using quality connectors. Invest in a quality tool such as a set of these:
The ones you get at most autoparts stores are complete shit
JimNut is offline   Reply With Quote
Old May 26th, 2013, 09:58 AM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you want to be able to unplug something buy some weatherpack connectors. they come in 1-6 wire configurations. http://www.electerm.com/index.html these guys are in royal oak and they sell what you are looking for.
Old May 26th, 2013, 10:02 AM   #17
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old May 26th, 2013, 08:37 PM   #18
Nuggets
I fix stuff!
Nuggets's Avatar
I solder and heat shrink everything I do. If the component needs to be removed, bullet connectors can be used.
Old May 26th, 2013, 11:01 PM   #19
bdd1469
bdd
bdd1469's Avatar
I used to use solder all the time but it is not the best for all connections. Soldering makes the wire brittle, and if you flex the wire it will break the soldered strands making your "best" choice a problem. They make such good weather pack connectors and similer connectors I rarely solder anything any more.
I did a lot of reasearch when I was building all new cables to mount my winch solonoid pack under my hood. Most every thing I read pointed towards a quality crimp with good tools being better then solder unless you are a pro, with the perfect wire, solder, and technic.
Old May 26th, 2013, 11:36 PM   #20
JeepInABox
In too deep
JeepInABox's Avatar
weatherpak
Page generated in 0.30593 seconds with 83 queries
