203 ro 208 transfer case swap? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2013, 10:59 PM   #1
sandguy356
bronco built for fun
sandguy356's Avatar
Default 203 ro 208 transfer case swap?
took the bronco down the road for the 1st time, about 35mph get this whine/howl and I swear it sounds like the damn transfer case. I dislike this 203 to begin with as there is no 2wd option and although I want to wheel the bronco, it will see a fair amount of time shuttling kids/wife to stuff over the weekends.
I have a c6 fronting it, has anybody swapped in a 208? It should be a direct bolt up, I might be reworking the driveshafts, but just wanted some advice on the swap.
sandguy356 is offline   Reply With Quote
Old June 8th, 2013, 05:34 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Direct bolt up to the transmission but you will need to modify both drive shafts.
NOT sent from an iPhone
Old November 3rd, 2014, 06:33 AM   #3
whouse88
F250 CUSTOM
Did you make the swap? If so what did you do with the 203?
whouse88 is offline   Reply With Quote
Old November 4th, 2014, 08:50 AM   #4
sandguy356
sandguy356's Avatar
I have not made this swap yet, still on the master plan to do it, but I have been slacking on getting it done.
That being said, the 203 is still in there. If I had someone that wanted it bad, I would work out a deal to get it sold.
Old November 5th, 2014, 01:48 PM   #5
chasetheface123
chasetheface123's Avatar
price? pm me
chasetheface123 is offline   Reply With Quote
Old November 5th, 2014, 02:06 PM   #6
trailrail302
Im going FAST!!!
trailrail302's Avatar
IF you need a 208 I have one, PM me if you need it
trailrail302 is offline   Reply With Quote
Page generated in 0.20948 seconds with 41 queries
