2005 Silverado Interior Leak - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2013, 09:58 PM   #1
Moose92
Many much Moosen
Moose92's Avatar
Default 2005 Silverado Interior Leak
I have a 2005 Crew Cab 2500HD Silverado. I found the carpet was wet on both the driver and passenger side. I pulled the carpet up and have found the water collecting at the front of the door frame, but I'm not sure where it is coming in. The water collected when I sprayed water along the bottom of the windshield, but I'm not 100% convinced that the seal is bad on the windshield since the water doesn't leak down the fire wall. Pictures are of the passenger side.
Has anybody seen this before?
ID:	106265   Click image for larger version
ID:	106266   Click image for larger version
Moose92 is offline   Reply With Quote
Old May 21st, 2013, 10:46 PM   #2
bdd1469
bdd
bdd1469's Avatar
If it has a removable cowl panel take it off and clean the drain out, they could be plugged with leaves and crud. Make sure the drain for the ac is clean and working properly.
If it has a sun/moon roof make sure the drains are clean and routed properly.
Check your door seals out for signs of water trails, chevys leak a lot of air and water around the doors, especialy extended cabs.
Check the seams for signs of a poor repair from a accident. Look for abnormal spots in the seam sealor or spots that have been repaired.
I have seen cars come from the factory with a seam that wasnt caulked on the line properly.
Check the bottom of your doors and make sure the drains are not plugged with leaves and stuff.
Sometimes you can use a spray bottle full of soapy water and compressed air to find your leak. Have someone spray it down and hit it with a blowgun while you watch for bubbles on the inside with a flashlight.
Old May 26th, 2013, 07:01 AM   #3
RADRICK
RADRICK's Avatar
x2 on what bdd says. I have also heard the soapy water trick but with the doors & windows closed and hvac blower on high. Just spray and look for the bubbles/
Old May 26th, 2013, 08:48 AM   #4
Toivo
Feel lucky?
Toivo's Avatar
Sprayable foot powder works great for trailing leak paths.
Old May 26th, 2013, 01:12 PM   #5
firehawk
Live Action!
firehawk's Avatar
Looks like the lower hinge is pulled away from the A-pillar, is it?
Old May 27th, 2013, 05:37 PM   #6
Moose92
Many much Moosen
Moose92's Avatar
No, the hinge is solid and working fine.
I also found a leak at the rear window.
I have an appointment this week to get the rear window and windshield seals inspected and hopefully repaired.
Old May 27th, 2013, 10:00 PM   #7
jessezipper
where you taking it???
jessezipper is offline   Reply With Quote
Old May 28th, 2013, 10:00 PM   #8
Moose92
Many much Moosen
Moose92's Avatar
I'm taking it to Henderson Glass on Canton Center.
Old May 28th, 2013, 10:55 PM   #9
jessezipper
did they fix it?
Old May 31st, 2013, 10:42 PM   #10
Moose92
Many much Moosen
Moose92's Avatar
yeah, found two leaks on the rear window. Then I found that the boot around the wiring between the door and the body was leaking. I resealed that last night and haven't seen any water in the front since.
Page generated in 0.28591 seconds with 54 queries
