Zf 9hp - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2013, 06:04 PM   #1
cerial
Direct Drive FTW
cerial's Avatar
Default Zf 9hp
Could the ZF 9HP be the next wave in off road transmissions?
The 2 speeds are fun in a straight line. But for practical cruising and lack of much low end they left me selling the car off quickly.
The 3 speeds were stupid tough and streamlined through leaps and bounds through the 60-70's. Making it my favorite automatic over the years. Cost and per foot pound the 3 speed was the king of the hill until the late 90's. I still prefer the low cost, simplicity, ease of use, and availability of a 3 speed.
The 4 speeds introduced overdrive and a tighter gear spread. Along with improved electronic lockup. But, I could not see a huge improvement.
The electronic 5 speeds were a improvement with better gearing and heavier duty applications introduced. The aftermarket built them further quickly ruling out the issues that left them with a nice run that still continues.
The 6 speeds were very nice with a great low range coupled with a great high while being more evenly spaced out. But, they had costly issues that I could not justify on top of being long and in most cases heavy. The ones that were built for heavy abuse were often very expensive.
The ZF 8HP I am very impressed with. Despite all the electronics which I feel will be it's largest vice in the upcoming years. Recalls and such a large employment will weed out most of those issues. Still the large size of such a unit will make placing it in any compact short wheelbase "crawler" or core will be difficult at best.
Then the clouds open up and we now have the 9HP. This ultra light, very compact, very strong planetary based unit could change the layout of buggies in upcoming years. Using mostly stock light weight engines this new transmission can allow for gearing and power/weight numbers unheard of. Once spooled/coupled with a 271 or planetary based transfer case through the use of the next generation electronically controlled torque converter this could produce big block power at a fraction of the weight.
Old May 21st, 2013, 06:15 PM   #2
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Troglodytes will only trust a th400 or 700r4.
I'll stick to a manual.
For daily driving hell ya id take an 8 speed!
I'm the man in White.
Old May 21st, 2013, 06:18 PM   #3
Mr.Green
I can levitate!
Mr.Green's Avatar
I am holding out for the HP11.
Old May 21st, 2013, 06:31 PM   #4
BlooMule
Old School
BlooMule's Avatar
My bicycle has 21 speeds.
-rw-rw-rw
Old May 21st, 2013, 06:40 PM   #5
cj65
cj65's Avatar
I have two speeds slow and sleep!
Old May 22nd, 2013, 01:27 PM   #6
kickstand
circling the drain
kickstand's Avatar
I can ride a bike with no handlebars
Old May 22nd, 2013, 02:45 PM   #7
Not really, just because in the real world, you don't want to be running a small engine at stratospheric levels. For certain areas, it works, but others, it doesn't.
Stock lightweight engines don't make 'big block' power. You might be able to get high whel torque at low wheel speed, but not power. Power output is independant of torque converters and gearing.
Its a 200lb front wheel drive transaxle, that handles about 350 ft-lbs of torque. Don't see it catching on....
Old May 22nd, 2013, 02:46 PM   #8
dreezy
Haggard Fab
dreezy's Avatar
Well I can split the atom of a molecule. OF a molecule
Old May 22nd, 2013, 03:59 PM   #9
Mr.Green
I can levitate!
Mr.Green's Avatar
I am suprised for one that Cerial of all people thinks that this is some magic trans that will make energy from nothing.
Old May 22nd, 2013, 06:00 PM   #10
Skooter_Built
Holocaust
Page generated in 0.34629 seconds with 52 queries
