99 blazer nightmare - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2013, 09:29 AM   #1
kyl_maxwell
kyl_maxwell's Avatar
Default 99 blazer nightmare
I have a 1999 blazer shut it off one day and it just keeps trying to start with key off and out of vehicle, pulled starter had it tested it tested fine, new starter relay didn't fix it, put new ignition switch in it didn't help. I'm out of ideas please help
kyl_maxwell is offline   Reply With Quote
Old May 21st, 2013, 08:45 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
check the wires that go through the firewall for any signs of water damage or corrosion. i have heard of wires chaffing on the firewall and shorting out the starter power to a battery power source. kinda rare but it has happened before. is the truck equipped with a remote start? if so unplug the module and see if that changes anything.
Old May 22nd, 2013, 09:31 AM   #3
kyl_maxwell
no remote start, i did notice that if you pull the starter relay out and put power to the vehicle the radio has power with key on or off but if you try and like start it the locks will start clicking up and down and it sounds like a loud humm
Old June 9th, 2013, 10:17 PM   #4
Dusty.briggs
Send a message via Skype™ to Dusty.briggs
Do you have any at audio in it?
Dusty.briggs is offline   Reply With Quote
Page generated in 0.18117 seconds with 35 queries
