Is resurfacing rotors/drums a lost art? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2013, 11:11 AM   #21
buttercr125
I work out
buttercr125's Avatar
I got two turn tables and a microphone
Old May 20th, 2013, 11:34 AM   #22
revho
$9.00 vanilla malt
revho's Avatar
New front rotors and pads for wifes 2006 honda element last week was $125.00 with a $25.00 mail in from Napa. I'm not messing with getting rotors turned for that price.
revho is offline   Reply With Quote
Old May 20th, 2013, 11:51 AM   #23
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Originally Posted by bdd1469 View Post
The cheap (exspensive/ junk) metal used to make rotors nowdays is harder to get a quality cut on in my exsperiece. They dont seem to stay true as well. That, along with the fact that rotors rust and deteriorate on surfaces that cant be turned make it easier to just buy new.
You can turn a rotor and still end up with a shimny or viberation because the cooling fins can rust away and throw the rotor out of balence. Twenty or thirty years ago you would never notice a unbalenced rotor because cars were not that smooth. Now cars are so refined you notice everything.
For most shops it doesnt make sence to turn when they can just slap on new ones and charge you the same $100 per hr. Plus mark up the cost of parts.
That makes sense, but not when I'm paying extra for better rotors in the first place. It's not a huge deal, but like kickstand said, it's just a waste. Why fix it when you can buy new??
Originally Posted by bigdgmc View Post
where did you go in alpena to have them turned?
I can't remember the name of the shop, it's the white building between mcds and kmart, something muffler shop??? Beavers said they turn them but told me no when I brought the rotors in; carquest said they couldn't be turned either. This was also for rotors on two different vehicles, 1996 chevy 1500 and 2006 colorado
Old May 20th, 2013, 11:54 AM   #24
wave_crusher
I'll Direc your TV
The sad part is i'm not even that old, 24, we used to turn rotors and drums all the time in auto. Now most people I talk to have no idea what i'm talking about when I mention it
Maybe it's not true now but I was always under the impression you don't need to replace the rotos/drums when you replace the pads/shoes, unless there was an obvious problem. I usually go about 2 changes of pads/shoes for every one change of rotors/drums, on the 96 anyway.
Old May 20th, 2013, 12:46 PM   #25
Brods
Yes
Originally Posted by Immortal View Post
Some places still do, but you would swear they used a brick as the cutting insert to turn the rotors!
X10 Dropped some drums off at a NAPA and paid. Picked them up and the kid said all they had was a broken insert, but he cut them anyway! WTF? And he could try to clean them up better if I liked. Oh and he could not refund my money, only the mgr who was not there...
On the flip side, as a kid working in an auto store I wish I had a dollar for everytime someone brought in a metal to metal worn rotor and asked to "just clean it up a bit". We had some of the really trashed ones hanging on the wall. Like the guy who put new pads in so ignored the noise and he kept driving until the rotor wore down to the fins. (Note: it works better if you put the friction side of the pad against the rotor.)
In the old days before the rotor eating semi-metalic pads, you could go through several sets of organic pads on the same set of rotors. Rear drums almost never needed to be replaced unless they went metal to metal.
Old May 20th, 2013, 03:24 PM   #26
kickstand
circling the drain
kickstand's Avatar
Originally Posted by rammanriley View Post
Did the rotors have a bunch of rust on the edges?
Don't all rotors have a bunch of rust on the edges a few days after they are installed?
Old May 20th, 2013, 03:26 PM   #27
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Even if you do find a place that will turn them if there is enough material there, the fuckstick making $8 an hour will probably fukc them up anyways. Had this happen to me on a rotor that listed $120 at the dealership, and wasn't available at the aftermarket level yet.
Originally Posted by Bones View Post
A lot of OEM rotors can not be turned. They are designed to be single use (not enough material to turn). Any decrease in rotating mass helps the EPA numbers.
x2.
Most rotors from the OEM are coated around the hub area and the vents. Most of the rotor hub rusting is a thing of the past, at least until they just get pretty damn old.
Old May 20th, 2013, 03:42 PM   #28
CSFJ
offensive 2 the sensitive
CSFJ's Avatar
Sadly I work with a fuckstick at a dealer who's been doing this for 30 years and he still can't turn a rotor without screwing it up.
CSFJ is online now   Reply With Quote
Old May 20th, 2013, 04:02 PM   #29
rammanriley
rammanriley's Avatar
Some do but what I was getting at is the ones that have pitting and you can't turn it out without getting under spec.
rammanriley is offline   Reply With Quote
Old May 20th, 2013, 04:17 PM   #30
kickstand
circling the drain
kickstand's Avatar
I knew what you meant.
Old May 20th, 2013, 04:19 PM   #31
Brods
How long ago is "a thing of the past"? Had to replace the rotors on an 05 because they were literally rusting to pieces from the inside out. The rotors on my Dana 60 put into service in 1995 are still in good shape.
Old May 20th, 2013, 05:02 PM   #32
GreaseMonkey
Pew pew!
'05 what?
Most higher end vehicles from 2008 on up have had coated rotors. Most of the cheap econoboxes now get it, but it depends on what MY the new vehicle launch was for.
Old May 20th, 2013, 05:03 PM   #33
ReiKo
Community Smart Ass.....
ReiKo's Avatar
More then likely your Dana 60 rotors were casted in USA and not China...
ReiKo is offline   Reply With Quote
Old May 20th, 2013, 05:29 PM   #34
Brods
'05 what? 05 Ram 2500 4x4
ok so 2008 and newer
Old May 20th, 2013, 06:00 PM   #35
GreaseMonkey
Pew pew!
Typically any model that has a new model year launch of 2008. Of course, there are always exceptions to the rule and finishes don't last forever.
Old May 20th, 2013, 06:22 PM   #36
14muddn
When I was a broke 16 year old it seemed worth the small difference vs buying new. Now I'm not going to stretch a 30 minute brake job a day or two because I'm waiting to get the rotors back... Ain't nobody got time fo that.
Old May 20th, 2013, 09:08 PM   #37
Kane
Got Jeep?
Kane's Avatar
I worked in a vw shop off and on for 15yrs and I cant put quality and water cooled vw in the same sentence.
You just did now. :)
Kane is offline   Reply With Quote
Old May 20th, 2013, 10:19 PM   #38
skife
skife's Avatar
When I was machining rotors in 2001, the TIR spec from mounting face of the rotor to the brake surface was .009mm. I wouldn't want to try to turn rotors to that spec on my lathe.
Surface grinder!
Old May 20th, 2013, 10:27 PM   #39
Flexin' XJ
Flexin' XJ's Avatar
I turned rotors all the time at the dealership. But, I remember us having to buy an "on car" brake lathe because when the Colorado/Canyon came out, that is the only way the rotors could be turned. Something about the rotor being part of the hub or something. Never ended up doing rotors on a Colorado or Canyon.
Unless the rotors were really rusty, I think they were just lazy.
Flexin' XJ is offline   Reply With Quote
Old May 21st, 2013, 08:00 AM   #40
wave_crusher
I'll Direc your TV
maybe that would be why lol, I just took in drums from the colorado, not rotors
Page generated in 0.40270 seconds with 83 queries
