Wanted cj5 window frame and 88 f150 coil springs - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Freebies
Old May 19th, 2013, 11:48 PM   #1
AtvNut
AtvNut's Avatar
Send a message via Yahoo to AtvNut
Default Wanted cj5 window frame and 88 f150 coil springs
Looking for a windshield frame for a CJ5 and a set of front coil springs for an 88 F150 4x4
Thanks
Thanks
Jeff
call or Txt
313-510-2083
AtvNut is offline   Reply With Quote
Old May 20th, 2013, 10:54 PM   #2
sandfox4
napadave
sandfox4's Avatar
what year cj5 ? i have one for top mounted wipers, like 55-68 ?
sandfox4 is offline   Reply With Quote
Old May 20th, 2013, 11:00 PM   #3
AtvNut
AtvNut's Avatar
70s cj if it will fit I would still use it
Thanks
Jeff
call or Txt
313-510-2083
Old May 22nd, 2013, 04:33 PM   #4
sandfox4
napadave
sandfox4's Avatar
i believe it will fit, just wont be able to use your original wipers, i want a $100 for mine, i can bring to silver lake if that helps, just pm me please
Old May 22nd, 2013, 04:58 PM   #5
AtvNut
AtvNut's Avatar
Don't have wipers now lol so it would work fine if it fits
Thanks
Jeff
call or Txt
313-510-2083
Old May 22nd, 2013, 06:01 PM   #6
dmcjeep
dmcjeep's Avatar
The hinges are going to be different between the 75 and earlier CJ 5 and the later 76 and newer CJ. Also if you are using a top the windshield frame are a different width at the top.
dmcjeep is offline   Reply With Quote
Old May 22nd, 2013, 06:50 PM   #7
AtvNut
AtvNut's Avatar
Not using a top but could it be made to work for a low budget trail rig
Thanks
Jeff
call or Txt
313-510-2083
Old May 23rd, 2013, 07:19 AM   #8
dmcjeep
dmcjeep's Avatar
If you have the whole hinge the part that bolts to the body and the part that goes into the windshield frame it should fit. You just need the hinges from whatever frame you are using.
Page generated in 0.38809 seconds with 47 queries
