TBI problem??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2013, 07:02 PM   #1
REPBOY
Big Rig Builder
REPBOY's Avatar
Default TBI problem???
Hey guys, I am having a probem with my 90 dodge w250. When I bought the truck, The guy said he had to pinch the fuel return line because the fuel pump was getting weak. Well I finally went to try and figure the problem out and the "fuel return line" was actually the main gas line leading into the throttle body. When I un-pinch the line, the truck will hardly run at all and has absolutely no pick up and will just bog out. The truck has a stock fuel pump so I dont think its getting to much gas from that. Im stumped... Any other ideas or things to check??? Thanks for any helpful input!
REPBOY is offline   Reply With Quote
Old May 18th, 2013, 08:09 PM   #2
REPBOY
Big Rig Builder
REPBOY's Avatar
Problem solved... Ended up finding a kink in the actual return line that was preventing excess gasoline to get back to the tank, therefore causing the engine to bog down when you floor it.
Page generated in 0.12934 seconds with 29 queries
