Does a 1997 vortec engine need oil / water temp signal to run correctly - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2013, 09:48 AM   #1
TJ SKWIG
Professional Dumbass
TJ SKWIG's Avatar
Default Does a 1997 vortec engine need oil / water temp signal to run correctly
Just wondering if a 1997 vortec 5.7L engine needs an oil pressure signal and water temp signal to the computer for the engine to run correctly.?? or are those signals just for the gauges? im doing a v8 swap on my TJ and want to install the jeep sensors on the engine to retain the stock gauges.
TJ SKWIG is offline   Reply With Quote
Old May 18th, 2013, 09:54 AM   #2
buttercr125
I work out
buttercr125's Avatar
No and yes.
Old May 18th, 2013, 10:03 AM   #3
TJ SKWIG
TJ SKWIG's Avatar
Originally Posted by buttercr125 View Post
No and yes.
not sure what that means.. can you be a little more specific?? lol
Old May 18th, 2013, 10:26 AM   #4
bdd1469
bdd
bdd1469's Avatar
Tj gauges run off of the jeep pcm. If you want to retain them you need to run both the chevy and jeep pcms. The chevy needs the oe sending units feeding the pcm to to run properly. If it doesnt see oil pressure it will not run, if it does not see temp it will run rich all the time.
Old May 18th, 2013, 05:29 PM   #5
TJ SKWIG
TJ SKWIG's Avatar
I have some people telling me no on the oil pressure signal to the computer, but yes on the water temp.. I do understand I have to run both pcm's for the jeep gauges to work. Just want to keep it as stock looking as possible.
Old May 18th, 2013, 09:02 PM   #6
jbeemer
Built not bought!!
jbeemer's Avatar
There is a oil pressure switch on the Chevy that runs the fuel pump relay, you will need that or a way to control the fuel pump.
jbeemer is offline   Reply With Quote
Page generated in 0.20713 seconds with 41 queries
