Does a Vortec 5.7L engine need Oil pressure/ water temp signal to run correctly? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2013, 08:46 AM   #1
TJ SKWIG
Professional Dumbass
TJ SKWIG's Avatar
Default Does a Vortec 5.7L engine need Oil pressure/ water temp signal to run correctly?
Just wondering if a 1997 vortec 5.7L engine needs an oil pressure signal and water temp signal to the computer for the engine to run correctly.?? or are those signals just for the gauges? im doing a v8 swap on my TJ and want to install the jeep sensors on the engine to retain the stock gauges.
TJ SKWIG is offline   Reply With Quote
Old May 18th, 2013, 08:58 AM   #2
in2deep
Hole tester
Temp yes. Oil pressure no
Old May 18th, 2013, 06:22 PM   #3
Iggy
Iggy's Avatar
Yes it does need oil pressure, the computer will cut out the fuel pump/ignition if the oil pressure drops below a certian level - I do not know what that level is.
Iggy is offline   Reply With Quote
Page generated in 0.20999 seconds with 32 queries
