Wheelbase....how long is too long? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2013, 07:55 AM   #1
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Default Wheelbase....how long is too long?
Truck is a 85 extended cab toyota pickup.....60 / sterling 10.25.....front links / rear leafs....40's.
in the process of putting it all together and I am sitting at 121". I know it's long and I am ok with that....but is it too long? truck will be used for general all around wheeling. I really can't move the front axle as it pretty much needs to be where it is to clear everything at full stuff....i can adjust the rear some if i really need to but i would rather not.
It previously sat at like 115" on 38's on toy axles and i had zero issues.
any input is appreciated
Old May 18th, 2013, 08:03 AM   #2
I am 104" on 40's. When wheeling with others that are longer, I have observed that 108-115" seems about right for 40's. Otherwise, unless they are ungodly high, when longer, they tend to hi center more often.
Old May 18th, 2013, 08:57 AM   #3
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am going to be low (less than 25" to the frame I believe) but I am nearly flat on the belly and the toyota drive train is pretty short and compact.....untill i link the rear about the shortest i could get is aroun 118" prolly.
the issue came in with the front because i had to shove the axle forward to keep the truck low while maintaing up travel and clearing the oil pan.
thanks for the insight
Old May 18th, 2013, 09:58 AM   #4
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
113" with 44" TSLs and 25" to the bottom of the frame with a flat bottom. The rear driveshaft is almost protected by the springs, the front is.
113" seems short when driving it. I can't go longer without linking (ran out of frame to mount hangers front and rear as I have 10' of leaf spring and 15' of truck).
wrath is offline   Reply With Quote
Page generated in 0.13128 seconds with 35 queries
