All wheel drive duramax - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2013, 02:55 PM   #1
DANOMAX
DANOMAX's Avatar
Exclamation All wheel drive duramax
hey I have a quick question. I own a 02 duramax and recently it decided that it doesn't wish to come out of 4wd. While I do like 4wd, its not cool all the time. I can hear the transfer case move but the front dif actutator will not decompress. once I disconnected the light blue wire the actuator recompressed. i have tried other actuators and same problem. why does the light blue wire have constant power? or does anyone know what the light blue wire connects too? is it maybe the switch, tccm, or encorder motor?? thanks for the help! -Dan
DANOMAX is offline   Reply With Quote
Old May 24th, 2013, 10:27 PM   #2
mtx410
Send a message via AIM to mtx410
light blue wire at the front axle actuator goes straight to the transfer case module. it's buried behind the dash. behind headlight switch. up high. sounds like that control module may be bad. I'd say it was the switch, but it sounds like the transfer case responds to the switch, just not the front axle.
mtx410 is offline   Reply With Quote
Tags
4x4 duramax
Page generated in 0.23695 seconds with 29 queries
