Silver lake sand dunes - advice - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Land Use > Rules, Regulations, Trail, and ORV Park Chat
Old May 17th, 2013, 06:42 PM   #21
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
With the right tire pressure u should be able to go just about anywhere in 2wd. Drop it until it looks too soft and then drop about 2 more lbs and it should be perfect.
Old May 17th, 2013, 07:05 PM   #22
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Originally Posted by GREASYHANDS View Post
I should bring my Toyota up there one day
In
Old May 17th, 2013, 07:17 PM   #23
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Alright thanks guys, like I said when it comes to steep hill climbing ill eithe get a good head start in hi or just go low. When I am encountering flatter light hills ill go high. I was at 8 psi last time but was scared my tires might pop off the rims. If I run the 31s at say 6 psi do you think they would pop off the 15x8 rim I have?
Wish I would have bought bedlocks back when I bought my MT classic chromes...but bal then I knew so little about cars/trucks I didn't even know what the point of bedlocks was
Catnip 0_o is offline   Reply With Quote
Old May 17th, 2013, 07:19 PM   #24
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
And anyone plan on going there June 20-26th? Ill be there
Old May 17th, 2013, 07:36 PM   #25
Deuling
Sand Slut
Deuling's Avatar
You will be fine on 6. Just don't do a bunch of donuts
Deuling is offline   Reply With Quote
Old May 17th, 2013, 08:34 PM   #26
Trail Junkie
iamfawkinwithyou
How wide are your 31s?
Old May 17th, 2013, 10:55 PM   #27
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
31x10.5R15
Old May 17th, 2013, 11:10 PM   #28
bacongrease
Am i still a Noob?
bacongrease's Avatar
There is no right pressure, but lower the better when horsepower is limited.
Invest in a really good gauge capable of reading in tenth of a psi increments.
In my deceased grand Cherokee on 265 75 16's I ran 5 psi in the rear and 6
psi in the front and never lost a bead and I tore it up pretty good, sharps
turns, couple of small jumps ect.
bacongrease is offline   Reply With Quote
Old May 17th, 2013, 11:55 PM   #29
93trackaddict
93trackaddict's Avatar
Originally Posted by Deuling View Post
True, but I have 408 cubic inches of small block chevy as well
You run 4 wheel with a 408?
93trackaddict is offline   Reply With Quote
Old May 18th, 2013, 12:09 AM   #30
Trail Junkie
iamfawkinwithyou
8" rims and 10.5" rims.....i wouldn't go much under 6psi IMO
Old May 18th, 2013, 01:20 AM   #31
Deuling
Sand Slut
Deuling's Avatar
I run 2 a lot. 4 is just mo fun. My rig weighs a lot more than a jeep too....
Old May 18th, 2013, 06:29 AM   #32
Originally Posted by Catnip 0_o View Post
31x10.5R15
Start at 8 psi
After they warm up some, drop to 6 if necessary.
Hi-Lo is personal preference and varies in every location at the dunes depending on your speed and desired results.
Out on the flats - Hi
Tight & Twisites - Lo
Small hills - Hi
Steep hills - Hi if you are going fast, Lo if you need more instant speed & are losing momentum in a higher gear.
What gear? Who knows, it's your rig, you need to experiment.
Best way to learn;
start out close to the bottom of a hill & hit it fairly slow. Go up the hill till you bog down. Stop, back down & either hit it a LITTLE faster or from a LITTLE further back. Make it so you learn how your vehicle reacts with SMALL changes in driving either by speed/momentum or acceleration. If you made it on your first try, you hit it TOO FAST. Back down and try it slower, till you can't make it. Many people are amazed at how easy hills are to climb with not nearly as much speed as they thought they needed.
Good luck and have a good time. Most of all, be safe.
Old May 18th, 2013, 09:10 AM   #33
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Start at 8 psi
Small hills - Hi
Best way to learn;
Very informative, I know last time I went there (my first time ever going offeoading) I used low a majority of the time, rarely used hi. Even in the flats I wss in low, probably a bad idea. I've been on a few other mud trips since and learned the way around my jeep some more since them but this time I want to experiment.
I did everything at silver lake last year other than test hill just because my jeep is also my daily driver and I felt I didn't have enough experience at the time. Instead I went up it with a guy I met there in his 4 banger YJ.
I'm thinking that if I run at test in hi gear, thn when I start to lose speed switch it over to N and pop it in low back to D I should be able to get over it. At what speed should you not switch over to low from hi and speed?
Old May 18th, 2013, 09:17 AM   #34
Trail Junkie
iamfawkinwithyou
You wont do it fast enough ....
Old May 18th, 2013, 09:21 AM   #35
Who knows? It's your rig. Tires, gearing, transmission ratios, whether you want to redline it all dictate.
Common sense prevails..................
Maybe if he screams while doing it...........
Old May 18th, 2013, 09:22 AM   #36
03tjsport
Red Dragons!
03tjsport's Avatar
And your transfer case will be very unhappy.
03tjsport is offline   Reply With Quote
Old May 18th, 2013, 09:34 AM   #37
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Haha alright looks like ill be experimenting..safely :p
Page generated in 0.36006 seconds with 74 queries
