Bent Shaft Fix? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 16th, 2013, 07:23 AM   #1
GearDrive
A little slow
GearDrive's Avatar
Default Bent Shaft Fix?
I have a rear axle shaft that is slightly bent. Can I remove the studs, put in lathe, and remachine the face square?
GearDrive is offline   Reply With Quote
Old May 16th, 2013, 07:32 AM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
You can, but you'd be taking away from the structural integrity of the shaft end. It'll probably break next time instead of bend
Old May 16th, 2013, 07:33 AM   #3
REPBOY
Big Rig Builder
REPBOY's Avatar
^^this
REPBOY is offline   Reply With Quote
Old May 16th, 2013, 07:44 AM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
I would put the shaft in a press and straighten it. Yes, the structural integrity will be compromised, but if you are on a budget, you can get some more run time out of the shaft. Since you have access to a lathe, a final cleanup after straightening might not be a bad idea.
Old May 16th, 2013, 07:54 AM   #5
GearDrive
A little slow
GearDrive's Avatar
I have driven on this shaft for 80,000 miles. It would just squeek and and wear out the pads every 30,000 miles. I replaced it last year with a good used one and now that one is bent to phuck from an accident. I think that I would only have to take off .010-.015 from the face to true it up.
Old May 16th, 2013, 08:32 AM   #6
If it is slightly bent, either fix will work without compromising anything. How far out is it? Is it the axle or the flange that is bent? If it is out very far, remachining the face will work but your studs will be slightly crooked.
This is a way over the top statement, especially when you don't know how bad it is bent. The OP says he has been driving it a long time but his brake pads rub. The only time bending something back impacts the integrity is if you are stretching the material to the point where you are starting to fatigue it. This DOES NOT happen in one bend.
Old May 16th, 2013, 08:36 AM   #7
GearDrive
A little slow
GearDrive's Avatar
I haven't put an indicator on it yet. I agree that trying to bend it back will fatigue it.
Old May 16th, 2013, 08:57 AM   #8
How so? Again, how far is it bent? You will not fatigue it unless you are stretching the shit out of the far side to bend it back. Do some research on the percentage of plastification while bending metals. You will find that what you are doing has very little impact on the integrity.
Take a piece of banding strap and put a slight bend in it. Bend it back straight. Now bend it again a little bit in the same spot. Did it break? No. Neither will your axle.
Old May 16th, 2013, 09:38 AM   #9
GearDrive
A little slow
GearDrive's Avatar
It's not bent much, but it already bent past its yeild point to cause plastic deformation. By bending it back the other way, you cause more plastic deformation in the opposite direction. I'm not exactly sure the kind of material or hardening used to make these axles, but I'm pretty sure it's not the same as banding material.
Old May 16th, 2013, 10:00 AM   #10
wave_crusher
I'll Direc your TV
You do know that he didn't say that he's been driving on it for a while until after I posted right? Take a look at the post again
Old May 16th, 2013, 11:30 AM   #11
Give me how much it's bent, where, material type and Ys and the dimensions and I'll tell you how much plastic you have bent it. My guess is it's a very low number. Do you realize that in almost any shaft manufacturing, the parts are bent and straightened during the manufacturing process? I have been in heat treating facilities where there are entire departments dedicated to straightening shafts.
Old May 16th, 2013, 11:57 AM   #12
GearDrive
A little slow
GearDrive's Avatar
I have seriously considered straightening it out. But all those factors are unknown to me. Instead of taking that chance I thought simply skimming the face would be a safe alternative. The area bent is probably between the induction hardened bearing surface and the flange. The material properties change in this short area. Since I don't have easy access to to the manufacturing and heat treating facilities, I've decided it would not be a good idea for me to try to straighten it.
Old May 16th, 2013, 12:44 PM   #13
sent you a pm.
Old May 17th, 2013, 06:31 AM   #14
GearDrive
A little slow
GearDrive's Avatar
It was out .018, turned it square. Will hope for the best.
Old May 17th, 2013, 01:28 PM   #15
.018", as in .009"/ side? That's nothin. Glad you got it fixed.
Old May 17th, 2013, 02:41 PM   #16
GearDrive
A little slow
GearDrive's Avatar
Thanks for the help Jim
Page generated in 0.67354 seconds with 71 queries
