Ramcharger Dana 44 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 15th, 2013, 09:57 PM   #1
jmgracing
jmgracing's Avatar
Default Ramcharger Dana 44 help
Hey guys im hoping someone can help. I have a bog Sunday and need my truck going. I have a 1993 Ramcharger with the CAN Dana 44 with the 2 piece axle shaft. Something happened and my spider gear grenaded. Took my carrier out, went to the junk yard and found the same carrier from at 87 Ram. Swapped my gear on to the carrier (i had 3:55 junk yard was 3:24) put it back together and its so tight i cant fit any shims and something.is not right because the ring gear is not setting into the pinion gear
Its barely catching. Any ideas or suggestions are greatly appreciated!
jmgracing is offline   Reply With Quote
Old May 15th, 2013, 10:10 PM   #2
littletrucker
I'd hit that
littletrucker's Avatar
not the same carrier? different carrier break?
Old May 15th, 2013, 10:25 PM   #3
Bo's Cj 7
Bo's Cj 7's Avatar
set both carriers on floor and see if the ring gear flange is the same height, probably not
Bo's Cj 7 is offline   Reply With Quote
Old May 15th, 2013, 10:32 PM   #4
koochman450r
koochman450r's Avatar
Put spider gears in your carrier. Should be fine.
you won this battle.
Old May 15th, 2013, 10:40 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
Carrier break is 3.91 for Dana 44. Did you put the"new" carrier in. with your old gear set?
Old May 15th, 2013, 10:44 PM   #6
jmgracing
jmgracing's Avatar
My carrier is pretty chewed up. I put my ring gear on the junk yard carrier which i assumed would be the same.
Old May 16th, 2013, 02:24 PM   #7
jmgracing
jmgracing's Avatar
You were right, my gear flanges didnt match up. Put my new spider gears on my old carrier should be good to go! Thanks so much
Page generated in 0.17247 seconds with 44 queries
