:FOUND!: ford fullsize dana 44 axle shaft pass side. spindle . hub - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 15th, 2013, 07:18 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default :FOUND!: ford fullsize dana 44 axle shaft pass side. spindle . hub
Broke the ear off from the ujoint body. Elongated the ears....so need new stuff.
Also could use a new ford spindle and hub...
Plato2k5 is offline
Old May 16th, 2013, 06:04 AM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Plllzzzzz
Plato2k5 is offline
Old May 16th, 2013, 07:37 AM   #3
addicted
addicted's Avatar
I ended up going this route on the hub when I was looking for one. http://www.napaonline.com/Catalog/Ca...943_0148359272
addicted is offline
Old May 16th, 2013, 08:08 AM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Are the hubs cast? Mine is just cracked at the end allowing crap to get into bearings.
Plato2k5 is offline
Old May 16th, 2013, 08:51 AM   #5
addicted
addicted's Avatar
I believe so. I had one with that same issue. I ended up with a new one after attempting to go used on it. The stud holes were less than tight on the used ones and the studs would practically push in with my fingers.
addicted is offline
Old May 17th, 2013, 12:02 AM   #6
johnjackpine
I'm not what year axle shaft you are looking for I have both the old solid axle style and ttb axle. I am located in Midland mi. I would like to get 40 dollars an axle shaft. I also have a whole complete ttb beam ford front axle I could sell you the hub and spindle out of that. My number is 9899282223. I would do 60 dollars on the cast hub spindle and axle shaft thanks john
johnjackpine is offline
Old May 17th, 2013, 06:15 AM   #7
Midnight Rider
I've got a complete solid hp 44 for $150 out of a 78 Bronco. I also have an assortment of TTB parts if that's what you need instead.
Midnight Rider is offline
Old May 17th, 2013, 10:35 PM   #8
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Thanks for the response guys! I picked up a complete axle lockout to lockout from a guy on craiglist.
Plato2k5 is offline
Page generated in 0.31057 seconds with 47 queries
