shock angles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2013, 11:26 AM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default shock angles
Need to fondest shocks on my stretched yj. What angle should I have the shock ?
Old May 14th, 2013, 11:49 AM   #2
32.498 deg latitude. See how relevant answers to abstract questions are
Old May 14th, 2013, 12:10 PM   #3
Deuling
Sand Slut
Deuling's Avatar
What's fondesting a shock?
Deuling is offline   Reply With Quote
Old May 14th, 2013, 12:15 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
haha fawk! I was on my phone at work ha ha ha......
I have a YJ that is SOA. Rear is stretched 6". I'm going to be running 14" travel bilstein 7100 shocks so I need to notch the frame and outboard the shock towers using the f250 style. I figure you do not want them straight up and down as when the leafs cycle, they swing back. So i would imagine you want to put a positive angle on them, so when they compress they become more straight.
Old May 14th, 2013, 12:23 PM   #5
Deuling
Sand Slut
Deuling's Avatar
I'm running mine how the raptor shocks mount? (I has raptor shocks) it's on a k5 but leafs springs are leaf springs.
Old May 14th, 2013, 12:45 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
so did you just place them and they looked good to you? I think i'm just overthinking this.......
Also, are those rock/debri/shit guards for the shafts? I like
Old May 14th, 2013, 12:48 PM   #7
Deuling
Sand Slut
Deuling's Avatar
I just stared at a fox raptor and did my best to keep it close lol.
And yes they are. Pretty bitchin.
Old May 14th, 2013, 12:54 PM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I remember seeing a cool write up long ago to figure the best, but here's a text version
Put shock in lower mount and droop truck completely.
Extend shock fully and swing it in an arc fore and aft while marking a piece of cardboard with a sharpie through the upper loop.
Bottom rear end out metal to metal, bottom shock out and swing fore and aft with sharpie through upper loop on cardboard.
Where those two arcs cross on the cardboard is the optimized location for the given shock, lower mount location and vehicle.
Move inward 3-5 degrees and call it a day. Sometimes the vehicle doesnt allow this due to frame rails or other restrictions but from scratch, no obstructions thats the way to do it.
or
Aim for 90 degrees at full bump. That is from the front leaf spring pivot, to the lower shock pivot, and then to the upper shock pivot. This creates a slight rising rate.
Old May 14th, 2013, 12:58 PM   #9
Deuling
Sand Slut
Deuling's Avatar
or
That's pretty cool!
Old May 14th, 2013, 01:48 PM   #10
^This assuming you don't have any revolver shackles or anything that could give you a goofy ass cycling pattern.
Old May 14th, 2013, 02:37 PM   #11
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
The 90s called and they want their revolver shackles back.
One thing the shortened write up doesn't mention is that to do it properly you should replace all secondary leaves with a spacer of equal thickness. That way you only have to compress the main leaf, and not your full spring pack.
Old May 14th, 2013, 03:02 PM   #12
Deuling
Sand Slut
Deuling's Avatar
Just did a write up on spring cycling
http://coloradok5.com/forums/showthr...Spring+cycling
Page generated in 0.37425 seconds with 59 queries
