Electrical corrosion causes? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 13th, 2013, 11:20 PM   #1
Wehan
Wehan's Avatar
Default Electrical corrosion causes?
My yj likes to go through the front fender side marker bulb sockets, they corrode the contacts away and then I need to replace them. What causes this and is there a way to fix this once and for all?
Wehan is offline   Reply With Quote
Old May 14th, 2013, 10:23 AM   #2
Outdoors
Field Repairs
Outdoors's Avatar
1. Moisture
2. Dielectric Grease
Outdoors is offline   Reply With Quote
Old May 14th, 2013, 11:48 AM   #3
firehawk
Live Action!
firehawk's Avatar
Salt and water
Old May 14th, 2013, 12:01 PM   #4
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Originally Posted by Outdoors View Post
1. Moisture
^ this
Old May 14th, 2013, 12:20 PM   #5
Wehan
Wehan's Avatar
1. Moisture
Thanks, I'll give that a shot.
Old May 14th, 2013, 12:56 PM   #6
Wehan
Wehan's Avatar
Ok so corrosion in the socket I get but how about this buildup of greenish blue on the pins inside the water tight sealed gm plug from my car?
Old May 14th, 2013, 01:39 PM   #7
firehawk
Live Action!
firehawk's Avatar
Yes that is corrosion. Moisture is getting in there.
Old May 14th, 2013, 02:05 PM   #8
Wehan
Wehan's Avatar
So pack that with dielectric Grease as well? Will it stop the current corrosion?
Old May 15th, 2013, 10:11 AM   #9
Outdoors
Field Repairs
Outdoors's Avatar
Don't pack it full, a little goes a long ways. Clean the connections, an place a dab on both spots. If the wires are not sealed where they enter the socket, I would put some there as well. It doesn't take a whole lot to protect the connection, and it's not like it gets consumed, it just sits there.
Page generated in 0.21642 seconds with 50 queries
