Bolt stuck in between my leafs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2013, 07:12 PM   #1
14muddn
Default Bolt stuck in between my leafs
When I installed my plow I should have put the head of the bolt outside. Recently the bolt end got caught in between the leafs and I'm not sure how to get it out safely. I thought of a cut off wheel initially but the end of the bolt is holding tension. I don't want an angle grinder knocked out of my hands when I'm laying on the ground. I tried unbolting it but no go and I can't get an impact in there either. Here is a picture to describe it better.
Old May 11th, 2013, 07:17 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
jack the truck up and support the frame to let the axle droop. hit the leaf springs with a BFH to get them past the bolts. then remove the bolts and reposition them.
Old May 11th, 2013, 07:22 PM   #3
Big pry bar pushing with your leg to let the springs off the bolt.
Old May 11th, 2013, 07:42 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Torch and stand back.
Old May 11th, 2013, 08:33 PM   #5
14muddn
3' prybar with a cheater pipe did the trick. The craftsman prybar was bowing pretty good and just like I thought the spring came down in a hurry but no injuries. No more leaning truck
Old May 11th, 2013, 08:34 PM   #6
Elvis13
Did you loosen the U bolts that go around the axle?
Old May 11th, 2013, 08:57 PM   #7
14muddn
Nope.
Old May 14th, 2013, 12:22 AM   #8
Wehan
Wehan's Avatar
Remove the shackle to relieve tension and see where that gets you.
Wehan is offline   Reply With Quote
Old May 14th, 2013, 12:36 AM   #9
chadcooper55
I think the problem is fixed.
Old May 14th, 2013, 09:44 AM   #10
bdd1469
bdd
bdd1469's Avatar
Torch those leaf springs out and four link it. Everyone knows plow trucks need to be linked for just this reason.
Page generated in 0.30256 seconds with 53 queries
