XJ: 99 XJ new engine no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2013, 01:42 PM   #1
burnsie
burnsie's Avatar
Default 99 XJ new engine no start
I just installed a Titan reman short block with a new head from National Cylinder Head.
Long story not so long, I put everything together, installed the motor and reconnected everything. When I went to start it I discovered that I had a battery and starter issue so replaced them. Went to start and all it did was crank, no spark but getting fuel. Through process of elimination I replaced the coil, CPS and the cam sensor and no start. I'm now getting spark but no fire. I've checked and rechecked all my grounds and still nothing. I've swapped out starter relays. There is good voltage going to coil and distributor and the plugs, cap, rotor and wires are all fresh.
I'm at a total loss, what am I missing?!?!
All thoughts appreciated.
Thanks,
Burnsie
burnsie is offline   Reply With Quote
Old May 11th, 2013, 02:21 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
out of time? does a 99 have a distributer?? or is it the newer 4.0
Old May 11th, 2013, 02:23 PM   #3
burnsie
burnsie's Avatar
It has a distributor. Just not sure about adjusting the timing on it.
Old May 13th, 2013, 09:45 AM   #4
burnsie
burnsie's Avatar
Yep, it's the timing. I went back over my assembly steps when I put the motor together and I realized that when I put the crank pulley on I didn't rotate the crank to TDC so my timing mark was not a zero. Such a bonehead rookie mistake but honestly it's the first time I've ever done a complete motor by myself. I'm disappointed for sure but I won't make that mistake again. Should hopefully have it running in a day or two when I get time to work on it.
Tags
4.0l, cherokee, jeep, xj
Page generated in 0.15585 seconds with 35 queries
