YJ: Spring clamp hits rear frame, SOA stretched. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2013, 12:37 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default Spring clamp hits rear frame, SOA stretched.
The clamp on the RE 1.5" SOA springs hit the frame, limiting flex.
I thought about doing the boomerang shackles, but do not want to add lift and cause a pinion angle change. Plus, the jeep sits level now front - rear.
Can I use wrap around style clamps vs the ones that stick up with a bolt going across with the gap?? Will that cause a change in suspension travel?
My rear mounts are welded to the rear bumper.
Or does anyone have plans to build boomerang shackles with zero lift??
Old May 12th, 2013, 01:25 PM   #2
cdw32
cdw32's Avatar
Besirk over on Jeepforum sells no lift booms. Made out of 3/8" stock really beefy. $25 for 2 shackles, meaning front or back. I have his 1/2" booms an am very happy with them. Not sure if booms woul do much in the way of fixing your issue though. Maybe use a regular spring clamp instead of the tall ones RE uses, might limit your travel a little.
cdw32 is offline   Reply With Quote
Old May 12th, 2013, 07:29 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I just made some 1/2" lift ones from 3/8 plate. Hope they work.
Page generated in 0.16272 seconds with 32 queries
