5.7 cracked head - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2013, 10:23 PM   #1
MichiganJeeper
Default 5.7 cracked head
Bought an 88 1500 with a tbi 350. has a cracked head was wondering do i need to buy tbi head specifically or can i use vortec heads??? any adice would help
MichiganJeeper is offline   Reply With Quote
Old May 7th, 2013, 10:53 PM   #2
Toyfish
Toyfish's Avatar
Vortec head will not work
Sent from my DROID X2 using Tapatalk 2
Old May 7th, 2013, 11:08 PM   #3
bigblockford79
Big Block Ranger
bigblockford79's Avatar
88 and newer will work, except vortec as previously stated. The 87 and older heads are also slightly different where the intake manifold mounts and therefore will not be a direct replacement.
Try contacting engine machine shops in your area, sometimes those places have common heads on the shelf ready to go for a good price.
Old May 8th, 2013, 12:31 PM   #4
I suck cocks. Lots of them.
locally famous
You could drill your intake to work with the vortecs
Old May 8th, 2013, 09:33 PM   #5
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Pretty much any TBI head will work. the biggest diff was in `86 when the carbs were phased out. if you use an older head the center two bolt on the intake on each side don't fit right.
Yetti
Old May 8th, 2013, 10:48 PM   #6
TboneK1500Z28
you can use vortecs, just use a carbd vortec manifold and an adapter for the tbi. you can use tpi heads or anything basically but id stay away from tbi heads in general. i have 4 tbi heads, one set has a good valves and seals, the other has good castings, i have new valve seals for them too.
TboneK1500Z28 is offline   Reply With Quote
Page generated in 0.30861 seconds with 41 queries
