Best method for painting a Deck railing/posts!? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2013, 09:23 PM   #1
barry1me
Just another day
barry1me's Avatar
Default Best method for painting a Deck railing/posts!?
I have about 150ft of deck railing/posts that I need to have painted. I have read about people using the $10.00 weed sprayers and filling with paint to spray....sounds crazy. Hand brushing this thing will take a ridiculous amount of time.
barry1me is offline   Reply With Quote
Old May 7th, 2013, 09:36 PM   #2
jaysusr
jaysusr's Avatar
Wagner
Old May 7th, 2013, 09:39 PM   #3
Mr.Moose
It's not that serious.
Mr.Moose's Avatar
The big thing is whether you are talking about paint or stain.
Paint, I use an electric airless sprayer.
Stain, transparent stain, you can use a garden sprayer. I have many times. But in both cases you have to make sure that things are properly covered/taped.
Many companies offer Solid-color stains; these are essentially paints.
Mr.Moose is offline   Reply With Quote
Old May 7th, 2013, 10:12 PM   #4
barry1me
Just another day
barry1me's Avatar
Im using Sherwin williams deckscapes or Duraction paint.
Old May 7th, 2013, 10:41 PM   #5
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
1. Buy balloons (small to medium size)
2. Fill newly acquired balloons with paint.
3. Rub paint fill balloons on taint.
4. ??
5. Throw balloons unmercifly at desired area.
6. Step back, and admire your art work.
Old May 7th, 2013, 11:45 PM   #6
14muddn
It's tedious doing it by hand for sure but I didn't want to dick around with cleaning overspray off of my house either.
I went with a 3 step process:
1. Get some beer
2. Invite a few people over
3. hand out paint brushes and beer
There, it's done in no time!
Old May 8th, 2013, 05:31 AM   #7
03tjsport
Red Dragons!
03tjsport's Avatar
Car wash mitten.
03tjsport is offline   Reply With Quote
Old May 8th, 2013, 05:39 AM   #8
RADRICK
RADRICK's Avatar
Originally Posted by 03tjsport View Post
Car wash mitten.
X2, with a rubber glove on your hand in the wash mit.
Old May 8th, 2013, 05:53 AM   #9
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Just tape and plastic off the house and any surrounding areas. Rent nice sprayer from depot. Done in a few hours with first coat and second coat later that day or the next. As for you just buy a tyvek suit from depot.
Silver Bullet is offline   Reply With Quote
Old May 8th, 2013, 05:56 AM   #10
Immortal
NO RELIGION WAT!
Immortal's Avatar
Be a paysomeonelser.
Old May 8th, 2013, 06:37 AM   #11
We always used an HVLP gun to do the rails and spindles. One person to spray, and a second person when close to the house, with a large flat piece of cardboard to block overspray from getting on things. 2 years building decks professionally, we never masked a house, using that method.
I will be doing my own deck this year, but I'll probably just use a garden sprayer (along with the cardboard mentioned)
Old May 8th, 2013, 07:14 AM   #12
barry1me
Just another day
barry1me's Avatar
do the garden sprayers work well? whats a HVLP gun?
Old May 8th, 2013, 08:01 AM   #13
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
High volume, low pressure... Refers to the amount of air required to use it.
Cheap Thrills Off Road
Old May 8th, 2013, 08:02 AM   #14
aber61
aber61's Avatar
Pump up sprayers work well for semi transparent stains. If you are using deckscapes solid color stain, do your rails and spindels first. Use a mini roller, hand mitt and a brush. Place a drop cloth under rail as to not soak the deck. Then roll and back brush the deck and don't paint yourself into a corner.
HVLP is high volume low pressure sprayer. They are a little tricky to use but you will still need to back brush or roll. Spraying is a transfer method of getting the paint or stain to the substrate. Still have to brush it on.
Duration is not good for decks. It will peel and lift off after the winter.
aber61 is offline   Reply With Quote
Old May 8th, 2013, 12:07 PM   #15
We sprayed penofin, rarely needed to go over it with a brush (we sprayed the whole deck, 2 coats), only in tight spots.
When I did it for my personal use, with penofin, I roll the surfacing, as it puts it on thicker and 1 coat suffices.
Or HVLP gun had a little electric air pump, worked pretty good. I was running the deck crew in 1994-1995, I'm sure things have progressed a little since I was doing it for a living.
Old May 8th, 2013, 02:46 PM   #16
Big_Awesum_Jeep
go to home depot and pick up a mexican
Big_Awesum_Jeep is offline   Reply With Quote
Old May 8th, 2013, 05:12 PM   #17
Elwarpo
The Warped One
Elwarpo's Avatar
If spraying watch for the wind, droplets can travel far and paint other things like furniture, cars, fences, houses...
Elwarpo is offline   Reply With Quote
Old May 8th, 2013, 08:14 PM   #18
barry1me
Just another day
barry1me's Avatar
Im using Deckscapes solid color on the decking, Im using Duration on the deck rails/posts. I like the idea of the paint mit, that sounds good. Any idea of a good brand or where I should get one of those at?
Old May 8th, 2013, 08:44 PM   #19
aber61
aber61's Avatar
Home Depot or Sherwin Williams have the paint mitts. They do leak so be sure to get rubber gloves as well. Get a pair, 1 for each hand. Carefull with Duration on flat surfaces, after 1 winter it will fail.
Old May 9th, 2013, 07:52 AM   #20
bdd1469
bdd
bdd1469's Avatar
We have tried all kinds of paints and stains and australian timber oil from sevens is by far the most durable product for decks, Imo.
We always pressure wash the deck a week before a dry spell so the water can dry. Then just sweep it and spray the oil on with a garden sprayer. A helper with a piece of cardboard as someone mentioned is a plus.
I dont like using a hvlp or other gun because you are always dragging the hose behind you and it is easy to mess up your fresh work a dirty hose.
Page generated in 0.55275 seconds with 82 queries
