I need a Rear Axle! Dana 70, 14 bolt, or Sterling 10.25 SRW - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2013, 12:13 PM   #1
AbsoluteRoyal
Post I need a Rear Axle! Dana 70, 14 bolt, or Sterling 10.25 SRW
Must be SRW and Full Floater
Complete axles preferred
4.10/4.11 gears
Working/good condition preferred
within 100 miles or less of 48615
8 lug by 6.5
Thanks for reading!
AbsoluteRoyal is offline   Reply With Quote
Old May 7th, 2013, 12:56 PM   #2
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
1983-1997 Regular cab short bed ford rangers had an 108 inch wheel base.
1998-2011 Regular cab short bed ford rangers had 111 inch wheel base.
Just some info to help.
lepp1892 is offline   Reply With Quote
Old May 7th, 2013, 01:01 PM   #3
I have an eb frame stripped of everything but coil buckets and engine mounts located in Hastings, MI.
Old May 7th, 2013, 01:26 PM   #4
AbsoluteRoyal
Thank you! I looked at the rangers a little in the past and had thought I needed a wider frame. Now I'm not sure and thinking something more narrow would work better.
I think the frame is too short, although I'm not positive. Thanks for the interest!
Old May 7th, 2013, 01:50 PM   #5
I also have a modified 96 f250 Std cab 8ft box frame that phase been modified in the front and shortened in the rear. When I was using it I think I was around 104" with rear springs and radius arm front. Motor mounts are ford.
Old May 7th, 2013, 09:19 PM   #6
AtvNut
AtvNut's Avatar
Send a message via Yahoo to AtvNut
I have a 98 explorer sport frame available
Thanks
Jeff
call or Txt
313-510-2083
AtvNut is offline   Reply With Quote
Old May 7th, 2013, 10:08 PM   #7
AbsoluteRoyal
I'm not sure... If I could get some pictures or possible check it out I could give you a definitive answer. Sorry for being vague! buying something while not knowing what you want probably is not the best protocol.
The frame is too short!
Old May 12th, 2013, 09:42 PM   #8
AbsoluteRoyal
Still looking for a frame and rear axle. Updated OP.
Old May 13th, 2013, 06:28 AM   #9
If you come get it, all you have to buy is fuel to get to me and to get you home.
Old May 14th, 2013, 08:45 AM   #10
busyfixin
Balls Deep
busyfixin's Avatar
I have a Scout II Traveler frame that originally had a 118" wheelbase. They are very easy to shorten/lengthen if needed. I'll be gone wheeling for a week, but when I gt back, I can get pictures and measurements if you're interested.
Old May 20th, 2013, 09:49 PM   #11
AbsoluteRoyal
Thanks everyone for the interest, I have purchased a frame that I think will be applicable. Currently I am in the market for front leaf springs(0 to little lift, something flexy and rated for 3000-4000 lbs) and a rear axle.
Old May 26th, 2013, 09:38 PM   #12
AbsoluteRoyal
still looking for a sterling 10.25 SRW rear axle in GOOD shape!
Old May 26th, 2013, 10:14 PM   #13
InTeRnEt_RyAn
InTeRnEt_RyAn's Avatar
I have nice 14B disk brakes
InTeRnEt_RyAn is offline   Reply With Quote
Old May 27th, 2013, 08:50 AM   #14
BIG AL
GO BIG OR GO HOME!
BIG AL's Avatar
Sterling here complete $100
BIG AL is offline   Reply With Quote
Old June 2nd, 2013, 05:55 PM   #15
AbsoluteRoyal
ttt
Tags
14 bolt, blazer, bronco, dana 70, sterling 10.25
Page generated in 0.26144 seconds with 68 queries
